Would there be any problems in sealing the crack up and not plugging the sensor in?
Or should i stop being a pikey and get a replacement?!
| Author | Subject: Standard throttle body question. |
martinh
Seasoned Pro Location: Bideford Registered: 08 Dec 2006 Posts: 1,274 Status: Offline |
its just a heater element so yeah it'll be fine.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
martinh
Winner! Thanks.Guess its worth sealing the crack up because as its part of the breather system or else i guess it will get messy? |
rikky
looks like the other outlet for the EVAP is snapped off toois it bunged up / filled? ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
martinh
Haven't looked to be honest mate! |
On the throttle body for the supercharged setup the whole black plastic area is done away with and just a metal sheet put over with silicone around it. Just do that if it's all cracked up.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
martinh
Thats a good shout mate! What happens to the breather pipe off the cam cover then? |
I would just source another black plastic piece, saves f**king about modifying crap needlessly.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I use an oil catch can. Though there's almost hardly ever any oil in it at all mostly condensation vapour have to empty it every couple of months. Engine doesn't inhale it's own oil then either.________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
stan_306gti6
Run the breather to atmosphere and then get the metal plate from Rich to cover where the broken heater is.Job sorted. ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
eddy_gti6
I have just put a blank over mine and not plugged it in. not had any issues with it like that so you will be fine________________________________________ Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url & = |
