Author Subject: engine wiring looms differences
cully
question for the peeps in the know
ph2 and ph3 engine looms what are the differences?
ive found the Map sensor plugs to be differant and so is the power steering pressure sensor plug are there any more?
will a ph 3 loom plug into a ph2 car and work if you fit the correct plugged sensors or ph3 engine?
Ph2 MAP
Ph3 MAP
Ph2 PAS sensor
Ph3 PAS sensor
Posted 28th Jun 2015 at 15:47
RallyeP6
On mine had a different gearbox reverse switch connector too.
Posted 28th Jun 2015 at 18:04
cully
will a ph3 loom work in a Ph2 car?
Posted 28th Jun 2015 at 18:05
pug_306
Yes buddy it will ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 28th Jun 2015 at 18:30
cully
excellent that's what i wanted to know Thank you Thumbs up
Posted 28th Jun 2015 at 18:39
I believe its only on an early phase1 gti6 there's a difference in which pin of the multiplugs or layout of the switched live that varies but easy to sort.
Posted 28th Jun 2015 at 18:41
cully
thanks ill have a look through SEDRE to see if i can spot the difference Wink
Posted 28th Jun 2015 at 19:05
