Author Subject: Fuel smell
Thomsongti6
Hey guys, today on this extremely rare hot Scottish day I noticed when I have the windows down every time I come to a stop I can smell fuel I can't really pin point exactly where it's coming from but it's definitely not from the vents, but I think the lambda sensor is goosed as I've been getting a slight misfire when cold and when under load could it be this? Or that Evap thingy?
Posted 11th Jun 2015 at 18:00
Check the fuel rail for leaky pipes
Posted 11th Jun 2015 at 19:44
Thomsongti6
Checked them no signs of leaks or cracks? Not sure now tank breather?
Posted 14th Jun 2015 at 17:41
Leaky injector seal ?
Posted 14th Jun 2015 at 17:54
Leaking Fuel filter Canister under the car drivers side ?
Posted 14th Jun 2015 at 19:13
walker_texasranger
Check the green and white square elbows where your fuel lines come into the engine bay. The 2" piece of fuel pipe that joins them and the circlips that connect it all are notorious for leaking, top left of the engine bay Thumbs up
Mine were spraying fuel straight onto the exhaust manifold when they leaked Yes
Hilux InvincibleX daily
306 No.13 Doh
Posted 14th Jun 2015 at 20:05
This...^^.
Most common fuel leak by far. Yes
Posted 15th Jun 2015 at 00:16
Thomsongti6
Sweet will have a look also had a look at my coil packs can see lots of little cracks but what cracks am I looking out for in particular? Any or certain ones? All 4 are slightly cracked Sad
Posted 15th Jun 2015 at 19:33
davidmartin
Had a leak in the same place a couple of weeks ago. fuel leak that is.
pet hate, the cat
Posted 16th Jun 2015 at 21:47
Dangerous stuff that Crazy
Hope mine don't ....lots have it seems Thumbs down
Posted 16th Jun 2015 at 23:27
That's the reason I have braided lines now mine were leaking and running down the inner wing.
Posted 28th Jun 2015 at 16:40
ad
I had a similar situation about a year ago, just bought a phase 3 and every time I opened the window it would stink of petrol to the point it was making me feel ill. When I shut the window the smell would go ( I thought it would be the other way) Anyway, there was a black ring in the boot that I wasn't sure what it was for (looked like a speaker surround)
Turned out it was the fuel pump ring thats under the rear seat, it was a right pain in the bum to get back on especially when it was a hot day and stinking of petrol. Had to put some serious pressure down onto it whilst trying to turn it with a flat head screwdriver on the ridges. I could see why the previous owner didn't bother putting it on.
Posted 5th Jul 2015 at 08:43
monty-69
If the smell is from the drivers rear wheel arch area its worth removing the arch liner and checking rubber filler neck elbow. They can perrish and give off vapours before they leakThumbs up
Posted 8th Jul 2015 at 00:00
Thomsongti6
I think it is coming from the offside rear tbh will check this weekend is there a breather next to the filler neck or is the Evap the breather?
Posted 11th Jul 2015 at 07:57
