cheers
1990 205 gti6 supercharged
| Author | Subject: pas relocation brakets |
stef306
Regular Location: lyme regis Registered: 20 Sep 2009 Posts: 203 Status: Offline |
wanted pas relocation brackets im aware they are available new from rich_w but just seeing if anyone has some second hand items.cheers ________________________________________ 1990 205 gti6 supercharged |
I found my old ones in the shed, here they are as they stand:![]() ![]() I've somehow lost the bushes that i used in the sump so they may not be much use to you, i think i just used m10 studding & half nuts to locate the pump. Interested? ________________________________________ Goldie the track car. |
stef306
yes i can made everything else give me a pm ![]() ________________________________________ 1990 205 gti6 supercharged |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
Who makes these ones? And what's the extra bit that sticks out?Stefan - I would check these fit first - looking at them, they space it out further from the sump than mine - you may find the pump hits the chassis cross member or rad as on the PAS 205s we've done it's very tight. ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
I had the above ones laser cut for mine a few years ago, the extra bit that sticks out is to attach a tensioner to the alternator.The part that sticks out was quite close to the radiator, and the pump was fairly close to the cross member so it would be worth checking the pictures in my project thread if you want to see it all in situ to check you are happy with positioning etc. ![]() ________________________________________ Goldie the track car. |
stef306
It's hard to tell the clearance as they will be in a 205 not a 306 and I wouldn't be using the alternator mounting. ________________________________________ 1990 205 gti6 supercharged |
Would a photo showing the distance between the sump and crossmember be any use to you?________________________________________ Goldie the track car. |
stef306
Yeah it would help thanks________________________________________ 1990 205 gti6 supercharged |
stef306
Do you not have one with the brackets and pump in place?________________________________________ 1990 205 gti6 supercharged |
Afraid these are the best photo's i've got, i can go and show the dimensions of the brackets if you want?![]() ![]() ![]() ![]() ________________________________________ Goldie the track car. |
stef306
every little thing will help me get a idea ________________________________________ 1990 205 gti6 supercharged |
rich_w
rich_w
My brackets in a 205________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Doh! That ain't fitting stefanie! ________________________________________ www.bridgecraftmotorsport.co.uk |
c_j_m
Seasoned Pro Location: Andover Registered: 23 Sep 2007 Posts: 1,917 Status: Offline |
Got a full rich w setup here.Inc all brackets, pump, high and low pressure lines, aux tensioner with rich w pulley. After £150 delivered. |
stef306
only need the brackets________________________________________ 1990 205 gti6 supercharged |
