displaying posts 1 to 2 of 2
Author Subject: PCV system
heliosphan
Is the PCV prone to blocking on these engines? It's occurred to me that I've never looked at mine and have no idea if it's functioning correctly. Maybe they rarely block on these engines though... Can the wire mesh separator unit be cleaned effectively or do they require replacement when they're blocked? I wonder if flushing/dunking it in degreaser or some petrol might clear it out.
Posted 30th May 2015 at 15:16
jimmyhackers
im a bit late to the party but, yes they are prone to failing, not exactly blocking. for a ten to thirty quid its definatly worth replacing. they usually fail by unblocking themselves and allowing too much oil into your intake.
they are a spring actuated diaphram thingy. they prevent engine vacum from sucking in too much oil into your intake but allow case pressure to be vented into the intake if needed.
they also minimise your oils exposure to external moist air, by sealing off your head, they help prevent condesate from forming in your engine.
you can clean it out but most likely if its been on there since factory the amount of oily crud and crusty rusty spring goop will be nie on impossible to get it to function properly again, the rusty spring will no longer hold pressure.
you can clean the pipes with a rag on a stick or use teapot/win bottle brushes. make sure your clean them thoroughly.....you dont want 20 year old rusty oil spring goop running through your engine.
Posted 27th Oct 2024 at 00:08
