Author Subject: Stuttering and misfiring
alcon
My car has recently started to stutter a lot and feels like its misfiring. At idle, it sounds rough and and you can hear the engine stuttering slightly. When driving it, particularly at lower speeds, it hesitates as you put the foot down and splutters its way through the rev range. At higher speeds out on the motorway it runs better as long as you have your foot planted otherwise its doing the same thing (stuttering) as at lower speeds. It's a pain when trying to move along in slow moving traffic.
Recently changed all the plugs a few months ago and all still look fine. VSS needs replaced and I have a new one but surely that wouldn't affect the running to that extent - especially as its doing it when idling??
Any ideas before I start replacing every sensor in the engine bay??
Thanks
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 22nd May 2015 at 12:44
RetroPug
Does the issue go away when it's warmed up, or get better?
Posted 22nd May 2015 at 12:50
alcon
Sorry, I meant to state that in first post.....no, the problem appears to get worse as the car warms up.
1999 Rallye (black)
Posted 22nd May 2015 at 12:53
rallyestyle
Have the same issue myself, think it's the lambda but havent got round to/been bothered to change it yet as don't use the car at the mo No Sad
Just Drive It
Posted 22nd May 2015 at 13:34
alcon
That may explain why it gets worse when it warms up. £69.43 from Euros right now....probably wouldn't do any harm to change it though.
1999 Rallye (black)
Posted 22nd May 2015 at 13:52
rallyestyle
Only thing is when i unplug my lambda i still get a similar issue so that makes me think perhaps it's not it. Have done the MAP sensor so it's not that, stepper motor done too and it's not that. Wondering if it's something like a damaged coil pack Unsure
It's odd though how it is perfect for 4-5 minutes from cold, suggests that it is triggered by some sort of sensor kicking in after startup or something.
Just Drive It
Posted 22nd May 2015 at 14:43
Mine ran like crap when I had issues with the green temp sensor.
Posted 22nd May 2015 at 14:53
daver6
Coil pack?
Wishbone Polybushes available
Posted 22nd May 2015 at 16:58
alcon
Ha!....you mentioned coil packs which gave me an idea. I swapped all four over with a known good set and problem solved! It's running as it should now
1999 Rallye (black)
Posted 22nd May 2015 at 17:49
rallyestyle
Sweet! Im deffo trying that out next then ;-) Thumbs up
Just Drive It
Posted 23rd May 2015 at 15:02
