Author Subject: Low Boost ECU
eddy_gti6
Whats different between the low boost lynx ECU and the standard ECU? Seen two different things, 1 saying its only a map and another saying its a chip. Are the low boost ECU mappable or not? Been looking at an eaton M62 charger and was thinking a low boost ECU may work with a few tweeks
Posted 12th May 2015 at 22:48
Niall
The lynx low boost uses the standard ECU with a reprogrammed chip. They are not live mappable in the way a Omex or DTA is.
Seeing as you will need a custom map for an Eaton, a standard ECU really isn't an option.
Posted 12th May 2015 at 22:49
luke306rallye
You could use a standard ecu or low boost mapped ecu, they're the same thing really. You'd have to get Wayne to map it for you though.
Posted 13th May 2015 at 07:13
rich_w
You can live map a standard ECU - if you have the right equipment - and Wayne is the only person in the UK for this.
The standard ECU could be mapped for an Eaton SC - Wayne has had a breakthrough with the standard ECU where he now has the ability to rescale the MAP sensor and let the ECU read boost - thus avoiding the need to put the throttle body on the inlet of the compressor, as we do on the low boost conversion.
Contact Details:
07732 822546
Posted 13th May 2015 at 07:57
rallyestyle
This is interesting Rich Yes So when i go high boost (ETA summer 2056) should i be looking to change the setup and reposition the throttle body?
Just Drive It
Posted 13th May 2015 at 09:21
eddy_gti6
Thanks for the info. Wayne isnt really too far away, couple hours down the A1. Rich does this mean i wont need to buy a low boost ecu as he would be able to map my wcu from standard?
I just thought i would ask the question as i cant see why the eaton cant be mapped on the standard ecu when the lynx kits can.
Posted 13th May 2015 at 10:11
russbez
interesting!
i mind him saying something about this when i was down... last year sometime
My Rallye project thread
Posted 13th May 2015 at 11:27
rich_w
You could do - although the setup we do works very well also - so I guess it depends if you want to go to the effort of relocating the throttle, fitting a DV etc. Would be interesting to though, plus you get woooop tiiissccchh noises LOL
Contact Details:
07732 822546
Posted 13th May 2015 at 21:43
Niall
TBH this is probably the best bit of having a boosted car LOL
Posted 13th May 2015 at 22:44
rallyestyle
Agreed... im sold LOL At least i have a while to figure out the changes, would be cool to look into it Yes
Just Drive It
Posted 14th May 2015 at 08:41
russbez
while we are on the subject
there much benefit of relocating the throttle to manifold?
besides the noise for you chavs Razz
Posted 14th May 2015 at 10:42
quicker throttle response one would imagine, also no issues with hoses collapsing under vacuum.
Posted 14th May 2015 at 12:47
marco gti6
This is good news Rich, are you thinking of making upgrade kits with say, dumpvalve and flanges to reposition the throttle body? Would we still need the ICV with this configuration?
I imagine there would be some interest from members who are low boost??
Posted 15th May 2015 at 08:29
rallyestyle
It's something i would be interested in Yes Cant be too much involved in switching around the position, will have a think about it over the weekend Smile
Just Drive It
Posted 15th May 2015 at 17:08
This might have been covered but a quick search didn't find anything; can the standard map sensor read boost with Wayne's breakthrough, and if so what sort of boost can it read up to?
If the standard one can't, is it a case of going down an aftermarket 3 bar type? Smile
Posted 2nd Jun 2015 at 22:12
rich_w
This isn't something I will make an upgrade kit for unless there's lots of interest and people willing to put their hands in their pockets and comit to it.
You would need a new flange for the inlet manifold welded on (to accept the TCool, new restrictor setup that works without the TB in that location, DV, and the ICV would need sorting out.
Electronically it would need a new MAP sensor (standard one only reads 1 BAR or atmospheric ) and new software Smile
Contact Details:
07732 822546
Posted 3rd Jun 2015 at 17:55
Nick.gti6
I'd be interested shortly but not just yet, bit low on funds. I haven't looked on the low boost I have just bought, but how does the brake servo work in relation to boost pressure not going into vacuum ect.. does it have a one way valve on it?
Posted 4th Jun 2015 at 09:04
You would need to put a one way valve into the vac system before the servo.
I've been thinking about doing this if I ever get time and less money commitments to go high boost. Was gonna look into DTA or Omex management with throttle body on the inlet and dump valve.
Gotta love the wooooop TISSHH noises LOL
As of later this month I have a garage at my new house I could build up an engine in (no room at work) so this is quite doable. But finances may not allow once I've moved so we shall see.
Posted 4th Jun 2015 at 10:21
Nick.gti6
So there would/should be one fitted on mine?
Posted 4th Jun 2015 at 10:58
rich_w
There is a one way valve installed already - this is standard, it's the white / black T piece type fitting Smile
Contact Details:
07732 822546
Posted 4th Jun 2015 at 11:19
Nick.gti6
Thanks Rich Smile
Posted 4th Jun 2015 at 11:31
rallyestyle
Id be interested to switching to this sort of setup as i will probably look to run my engine with aftermarket management so may as well get the ebst out of everything.
If you had some idea of the work involved and what sort of price you would exepct it to cost Rich that would be cool, happy to commit if it's within my means Thumbs up
Just Drive It
Posted 4th Jun 2015 at 12:12
jaredboy
Me too:-)
ZX 16V
Posted 4th Jun 2015 at 16:37
marco gti6
Same here Thumbs up
Posted 6th Jun 2015 at 10:17
