Author Subject: Has anyone seen these wishbones before?!
reese
Hey guys,
After seeing all of the good reviews regarding Motaquip wishbones I decided to try and get hold of a set.
I got them from a company called Autoparts here:
http://www.autopartsonlineshop.co.uk/vsa916a-bottom--control-arm---citroen-xsara-picasso-peugeot-306mk2-partner-1996-2011-97-p.asp
They match the part numbers specified in the Motaquip catalogue but they look like they are manufactured in a different way and appear to be solidly cast as they weigh a fair bit. The ball joints don't look to be replaceable as per normal wishbones either.... Has anyone have any experience with them?
Thanks Smile
Posted 12th May 2015 at 22:45
eddy_gti6
Wont fit a 306, there is no hole in the top of the P bush to bolt the ARB bracket into
Posted 12th May 2015 at 22:49
Niall
The ARB clamp just fixes down using the same bolt that holds the P bush down. It just sits on top
They look like they will fit but are a bit odd!
Posted 12th May 2015 at 22:53
pugheaven
Thing is if the balljoibt goes you will have to replace the entire wishbone unlike the standard set up
Posted 13th May 2015 at 07:12
They are late xsara picasso and van arms, they will fit but youll need a different bolt into the bottom of the p-budgt due to the alloy body having a different thread.
fook knows what eddy is on about as the hole is clear as day in the pics LOL
Posted 13th May 2015 at 07:59
reese
Thanks for your replies.
Does anyone have the correct part number for Motaquip wishbones?
On their online ecat (http://www.motaquip-ecat.co.uk/) it states the following:
Mk1 306 (1993-1997): VSA914 (Left), VSA915 (Right)
Mk2 306 (1997-2003): VSA916A (Left), VSA917A (Right) (These are the ones I have ordered)
Cheers guys
Posted 13th May 2015 at 11:48
pugheaven
I think he is on about the little threaded hole that just goes into the Bush area and only connects to the subframe to stop the p Bush turning
Posted 13th May 2015 at 13:41
pugheaven
The mk1 will have 16mm ball joints the mk2 18mm
Posted 13th May 2015 at 13:42
eddy_gti6
Yeah sorry that was what i was on about, thanks ollie. My mistake
Posted 13th May 2015 at 16:45
