Author Subject: VSS information needed
my3AWDgst
Hey guys,
Here in US we have no electrical diagrams or shop manuals after 91 and google was not much help. I need to know which pin on sensor it self is 12V,power and ground. Also what type of the sensor it is? Resistance values would be very helpful.
Thank you in advance.
Savo Stanivukovic
90 405 Sport Wagon 306 GTI 6 swapped.
89 405 MI16 ECMlink,SD,E85 swapped.
89 405 MI16 (standard)
91 405 MI16 (Sorento Green)
91 405 MI16 parts car.
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
2010 Genesis coupe track edition.
Posted 9th May 2015 at 14:27
cully
1=12v
2=grnd
3=signal
B33 on the first drawing
http://www.306gti6.com/forum/showthread.php?id=134863
Posted 9th May 2015 at 15:43
my3AWDgst
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 9th May 2015 at 21:13
my3AWDgst
Would you guys know if pin #1 is on the left or right? Does is still go in same order 12V,G and signal?
Thanks.
my3AWDgst has attached the following image:
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 00:54
its not the same as one has two pins..
the plugs are numbered.
Posted 29th May 2015 at 07:48
my3AWDgst
Ohhhh come on now man it's obvious that one is three pin and one is two pin...I should have wrote it up better. That picture was taken for US website to show the difference between the two however one on the left is not numbered and I need to know which pin is #1 and which is 12V,G and signal.
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 08:18
look at the plug.
Posted 29th May 2015 at 08:49
my3AWDgst
I'm running Mitsubishi fuel management system,speed density and E85 fuel and in order to log vehicle speed I had to get that 3pin pug VSS and I need to make sure that 12V,G and signal is in same spot as Mitsubishi so looking at Mitsu pin lay out does not help me. Hopefully this clarifies it little better.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 09:07
look at the Peugeot plug, any 3 pin one.
Posted 29th May 2015 at 09:39
cully
12v---0v--sigV
pin1---2---3
Posted 29th May 2015 at 10:11
my3AWDgst
I'm not sure how well you remember but Motronic 1.3 did not have 3 pin conectors and only one I remember it was 3 pin was IAC so that's no help at all. I'm no longer in Motronic possession any longer and my XU10J4RS is still stuck at customs in New York so there is no way for me to look at the harness.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 13:36
my3AWDgst
cully wrote:
12v---0v--sigV
pin1---2---3
Thank you cully.
Does same pins assignment applys to this non GTI VSS?
Looking at my picture (VSS on the left) is pin #1 on the left of it? I'm asking because I'm not sure if I rotated it correctly in the picture for you to identify pin #1.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 13:43
cully
that left vs sensor is not a gti6 gearbox sensor as it is keyed wrong on the plug
Posted 29th May 2015 at 17:31
cully
Posted 29th May 2015 at 17:47
my3AWDgst
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 29th May 2015 at 20:24
my3AWDgst
VSS end up working just fine. I had to switch pin#1 with pin#3 as Mitsu 12V and signal was on opposite sides. ECMlink is reading it just fine all I had to do was to adjust speed under speed tab so ECMlink's speed is matching vehicles speedo.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 10th Jun 2015 at 12:54
my3AWDgst
It was hard to take picture while driving.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 10th Jun 2015 at 12:56
my3AWDgst
And vehicles speedo.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
chiefton
Car collection looks good any pictures?? Sorry for being off topic! Lol
cherry rallye daily (the money pit)
