Author Subject: Lowering
tdawe1989
This may be a bit of a silly question but can I lower my 6 just with a coil over kit or would I have to lower it off the torsion bar, and also what would be the best coil over kit to buy?
Posted 27th Apr 2015 at 11:39
you can just lower the front if you really want to, would look daft though.
on a budget, best bet is a set of eibach springs, next up would be some bilstein or koni dampers and eibach spring, after that a kw or ast or bilstein coilover.
torsion bar adjustment is advisable with any method, as is increasing rear spring rate.
Posted 27th Apr 2015 at 11:57
tdawe1989
I have ebiach andbilsteins on front so its slighly lower on the front but I want to lower the rear, so the best thing to do is still lower it on the torsion bar too?
Posted 27th Apr 2015 at 12:51
orta
It was level 30mm when I had it. And yeah whatever you go for on the front you'll need to Match by lowering the bar
CLUB BLACK RALLYE
||B8s||60-70mm drop||Black Partner Steels||P1 VTS Rack||Refurbed Beam||Hybrid ARB||VTS Torsion Bar||
Posted 27th Apr 2015 at 13:20
