208 GTI OwnerTurbo'd '6 project - work in progress
| Author | Subject: standard FPR |
craig903
Regular Location: whitstable Registered: 08 Jul 2013 Posts: 273 Status: Offline |
Hi, when boosting a '6 can you use the standard fuel pressure regulator? It looks to me as if its veriable depending on the vacuum in the manifold so this wouldn't work properally when boosting as it would be pressurized? ________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
What you say makes sense yes. What you change to I guess depends on how your fuel management will work, pressure, angle, duration control by the ecu etc etc________________________________________ Nothing to see here |
yes it will still work properly, im uncertain if these will do it but theory is that give it boost abd youll get more than 3 bar, what it does as standard is reduce the pressure when the throttle closes, I.e under vacuul.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
