Author Subject: Shorter VTS 5 Speed Box Help
hepkem
Hi Guys.
I drive ph1 Xsara VTS ITB setup once in a month at Istanbul Park. It's a 5km long and quite fast track.
I have original 5 speed VTS box and here's the dyno graph from Mustang Dyno ;
It's 188ps and 177nm at the wheels so 229ps and 216nm at the crank.
Here's a video from the track day session from last Sunday. I had varex exhaust problem, electric motor was stuck just before the 2 sessions I had so engine wasn't revving well at high rpm's. You can jump to 3:05 to see best lap ;
https://www.youtube.com/watch?v=BGR0IAHerOw
I can reach upto 196-198km's on the last straight based on HLP.
VTS's 4th and 5th gears are quite long. I plan to shorten 4th and 5th gears.
I hope guru's from the forum check above info and tell me if that's a good idea.
How can I do above if you recommend so ? Which parts I need to buy ? Any part numbers or sources recommended ?
thanks
Kemal
1999 Xsara VTS ITB
Posted 15th Apr 2015 at 21:44
Well... You can build a box using various different Peugeot BE box parts. Welshpug will be along at some point to explain exactly what he built into my box. Max speed at 7k rpm is 127mph. It's awesome...
Posted 15th Apr 2015 at 21:06
Mossy1985
What is your box built for Adam? Close and low ratio? Im interested in what Welshy put together for you
Posted 15th Apr 2015 at 21:11
4.42 FD with 205 gti gears, only possible with BE1 and early BE3 shafts, later BE3 4.42's were BE4 style and used a double spline under 3rd & 4th so the 205 stuff wont fit.
its very close to the ratios of the 6 speed box but with shorter 1st and 2nd, and no 6th.
if you are getting to 200 kph then that's probably the limiter in 4th, it really doesn't take my zx long to get there and I'm on a standard xsara box.
Posted 15th Apr 2015 at 21:20
Mossy1985
First seems long in the 6 to me. I would be happy with 110 mph max in my sardine tin, wouldnt dream of going faster without a cage etc. Probs be in a box after a crash at 50 in one of theae things
Posted 15th Apr 2015 at 21:26
tsd167
when did the later be3 start production,can i not put a 205 gti gear set in my 2001 vts.
Posted 15th Apr 2015 at 21:31
no, you'll have a BE4 box in an 01 car, the later BE3 stuff was around 97-98, the gti6 box is a BE3-4 hybrid, half the casing is stamped BE4, half BE3!
Posted 15th Apr 2015 at 21:47
hepkem
My car is ph1 1999 model vts, how can I undertand if it's early or later be3 box ?
which 3rd-4th and 5th gears I can use if that's a later be3 model ?
1999 Xsara VTS ITB
205 gti 1.9 I believe.
Hi Mossy, it's built for anything really. Track, sprints and hopefully some sort of rallying. It's mega until you sit on the motorway for 2 hours. My car uses a standard gti engine but is a bit lighter. 110 max would be awful - I'm in 5th for a lot of road time anyway and I'll hit 115+ at combe. Nearly did 110 at pembray sprint last weekend...
Posted 15th Apr 2015 at 22:51
ive never looked into what later vehicles have ratios of be4 style similar to the 205 yet, as ive had early final drive shafts to hand.
might be something from the 206 or 207 gti
Posted 16th Apr 2015 at 09:11
hepkem
Some local gearbox techs told that 307 1.4 hdi and several other 5 speed box gears can be used but they wanted me to take the gears out first.
I guess I should change final drive first and shorten all the gears and try than dive into changing gears.
1999 Xsara VTS ITB
Posted 16th Apr 2015 at 10:12
hepkem
I have checked possible FD upgrade options on teammfactory web site and found that 4.9-5.0 range FD will be very good for me ;
http://www.teammfactory.com/gear-calculator
Is there any of the shelf or used gearbox FD which I can use in BE3 box with 4.9-5.0 ratio ?
1999 Xsara VTS ITB
Posted 17th Apr 2015 at 13:07
miles
Yes, a Citroen Belingo van of some sort, finding one thou well is pot luck, I paid £30.00 for mine but you need to make sure it's the right type as the shafts are different Dia
www.pugracing.com
Posted 17th Apr 2015 at 23:51
RaceR
you can use this Wink
Download HERE
Posted 18th Apr 2015 at 07:58
