Author Subject: Fan Relays
ash j
Hi guys
My 'STOP' light has been constantly on for around 4 or 5 weeks now.
It's not a '6, but a 2001 Phase 3 1.8 16v with air con.
When I unplug the brown sensor with ignition on, the fans do not come on at all.
The light came on and stayed on after I gave the car a thorough clean so I know I have got water in either the Bitron unit or the relays at the front of the grille.
I have already sourced a known working Bitron unit so am going to fit it this weekend. However, it could equally be one of the two relays which I believe sit behind the grille? So I may as well try and get these as well so I can definitely sort out the problem this weekend.
Does anybody have these two relays which are in known working order please? The Bitron unit on my car is exactly the same as the GTI-6 one for the same year, so I assume the relays from a '6 will also fit my car.
Let me know if you have anything!
Ash
Posted 15th Apr 2015 at 10:48
ash j
Okay so I think there are actually three relays. Two black and one green?
So could do with all three please.
Posted 15th Apr 2015 at 11:02
cully
think it should be 2 green and one black Wink
Posted 15th Apr 2015 at 12:46
ash j
Now sorted.
Thanks
Posted 15th Apr 2015 at 17:21
Did you get used or new in the end?
Posted 15th Apr 2015 at 22:49
ash j
I bought this..... http://www.ebay.co.uk/itm/PEUGEOT-306-AIR-CON-COOLING-FAN-ECU-AND-BITRON-FAN-RELAY-BOX-/291424551865?pt=LH_DefaultDomain_3&hash=item43da41c3b9
So used in the end, apparently all in perfect working order however.
Posted 16th Apr 2015 at 09:00
