Author Subject: lower strut brace engine mount
pugheaven
Just wondering if anyone else's Phillip M lower strut brace is hard up against the sump and acts like a mount Dunno
Posted 7th Apr 2015 at 19:51
superchargedblack1997gti6
I had my sump shaved a little to stop this mate Smile
Posted 12th Apr 2015 at 19:52
Don't think mine is, I'll check it for you tmmrw but I should of noticed if it was,
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 12th Apr 2015 at 20:52
Mines nowhere near the sump and even it wasn't sat further back from the sump it would still clear it as its a good bit below.
Posted 13th Apr 2015 at 20:37
Niall
Yep mine used to rub against the sump. Made an annoying noise on pull away. Odd though as with the old engine in, it was fine!
Posted 13th Apr 2015 at 20:38
pugheaven
Andy your brace looks like it sits a good few inches aft of what mine does, might just be the angle of the picture though.... Can you take one from directly underneath the brace so I can compare it against mine.
Is yours the twin tube brace?
Posted 13th Apr 2015 at 21:21
Mine is a twin tube one and clears with ample space. Few photos i found on my photobucket.
Posted 13th Apr 2015 at 21:32
pugheaven
Wtf is going on with mine then! I'll get some pics tomorrow but mine sits against the back edge of the sump, the lower engine mount fork is connected with solid mounts so it's not like the rubber has gone and allowed the engine to swing aft!
Strange, very strange
Posted 13th Apr 2015 at 21:43
I will do but it looks exactly the same as above but blue, twin tube and sat in exactly the same place as above
Posted 13th Apr 2015 at 23:15
aaron6
Measure the length of the mounting tube. I suspect that yours will be longer than the other if your hitting the sump.
Posted 15th Apr 2015 at 07:35
