Put the new ones on, bled the air out, but now the peddle has a lot of travel on it.
Is there still air in the system?
I've double checked for leaks and all good.
Any solutions appreciated.
Team Diesel
| Author | Subject: bleeding rear calipers |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
Changed out my old calipers for a set i refurbed today, the swap was easy apart from a stubborn brake line bolt.Put the new ones on, bled the air out, but now the peddle has a lot of travel on it. Is there still air in the system? I've double checked for leaks and all good. Any solutions appreciated. ________________________________________ Team Diesel |
*Pedal. Peddle is what you do when you have wares to sell.clamp the load compensator in the loaded position or place the car on its wheels, ensure the load compensator isn't seized. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
Where is the load compensator________________________________________ Team Diesel |
cornish_pug
Its fine when I'm stationary, as soon as move off the pedal gets travel________________________________________ Team Diesel |
cornish_pug
If this is what you mean, I haven't seen one on my car. cornish_pug has attached the following image: ________________________________________ Team Diesel |
