Author Subject: Bleeding After Taking System Apart
Eddleston
As most of you know I've had the abs and all piping round the bay out the car. I've started bleeding it through today and all I get out the rears is fluid, then plenty of air out the fronts. Great, I'll just go round again, no worries.
Now however I can hear the air going through the ABS but the system doesn't seem to take any more fluid.
Is there a trick to making the air go out of the ABS lines or do I just keep going? Annoying as so much fluid came out the fronts after a short time.
Posted 5th Apr 2015 at 15:20
get a pressure bleeder, also make sure the rear is loaded or at least the compensator clamped in a loaded position.
Posted 5th Apr 2015 at 15:36
Eddleston
Pressure bleeder decided not to stay attached. I now have a bit less red paint on the engine bay Sad
I'll drop the back back down too, cheers.
Posted 7th Apr 2015 at 11:28
derp, too much pressure at a guess? I have a modified o.e cap on my pressure bleeder too.
Posted 7th Apr 2015 at 13:16
tvrfan007
If the car is driveable you can cycle the ABS on a gravel car park/grass field and it will release.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 19th May 2015 at 10:10
