Author Subject: No power on 1st and 4th.
yanni
Hello all
Simple question for the gurus!!! Engine runs on 2 cylinders only. Diagnose shows no spark on first and fourth cylinder and no power on the corresponding injectors!!! Any clues what to look for???
Many thanks.
Yanni.
Major stock holder of group P.S.A.
I live to pay and support the French industry.
Posted 1st Apr 2015 at 18:36
which ecu?
I would check the double relay.
Posted 1st Apr 2015 at 18:47
pug_306
which ecu?
This. On the Phase 2 its the brown relay :-)
1992 205 GTi6
205 Turbo 340bhp
Posted 1st Apr 2015 at 19:16
yanni
Sorry i didn't clarify.
Car is Xu10j4RS Citroen Xsara Mk2 three plug multiplex ECU!!!
Just drives us crazy for no apparent reason....
Yanni.
Posted 1st Apr 2015 at 19:19
I'd be looking at the continuity from the injector plugs and coils back to the double relay then Smile
Posted 1st Apr 2015 at 19:33
rich_w
Check the following:
- Injector / coil wiring continuity to ECU, and leaks to earth
- Injector resistance
- Coil packs
- Failing that, it may be a failed ignition / injector driver in the ECU
Contact Details:
07732 822546
Posted 15th Apr 2015 at 10:47
yanni
Update.
It seems that it's was none of the above. In the MK2 Xsara Xu10j4rs engine ECU Citroen decided to change the software so the immobilizer is embedded in the ecu map and has a rolling code. Now the problem is that trying to unlock the immobilizer confuses the engine map thus the engine runs poor or not at all. Only solution is to clone the BSI module under the dash from another car and code it to the ecu with that map. After two weeks that was the solution and now two cars runs fine with the same software and codes.
Job done.
Thanks for the replies guys Thumbs up
Yanni
Posted 15th Apr 2015 at 11:41
