Author Subject: Budget 306 Build
Maxi rally
Ok so I have a few 306's
I managed to crash the group A one into a tree, so its in rebuild phase....I am telling myself It needed a freshen up anyway, just so I fell better....Big grin
So being without a race car was in tolerable. So I built a 4 week budget special!
Cheap car off the internet inc Konis, 2" exhaust, cams and few nice little bits.
Stripped for lightness
Add a bolt in cage (similar to a UK spec bolt in)
Some fancy stickers - creative vinyl and yes it was painted with a spray can....!!!
Blanked the sunroof of with a alloy sheet.
Add a 3J LSD
Seats and Belts....
And you get a basic race car for 1500 quid
Not bad I say
Posted 31st Mar 2015 at 06:14
pebbles167
Change the wheels to something sporty looking, and that would be superb!
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 31st Mar 2015 at 08:03
MisterGTR
I love how matter of fact you make all that work sound Smile
Nice work
Posted 31st Mar 2015 at 08:28
RetroPug
If it has a gti6 engine in it 2" is a bit small? Standard diameter is 2.25".
Posted 31st Mar 2015 at 12:43
Puggitt
Looking at it I'd say it's a xu10j4 engine not the remodelled Rs with the nice alloy inlet and plenum
Posted 31st Mar 2015 at 18:02
which still used the same exhaust system as a gti6.
Posted 31st Mar 2015 at 18:13
Maxi rally
Ah yes, it is 2 1/4 inch exhaust, engine is a std S16 with a K&N filter, Stage 1 Cam and has had a rebuild at some stage prior to me getting it. It was bought off the net.
Runs the 5 speed box.
The wheels came with it, getting aftermarket stuff here is expensive so given it was always a budget build they are fine. I do have a set of 17" wheels that I am chasing the 20mm spacers for that I may use.
It's easy to keep spending, at this stage only a higher spring rate, better brake pads and a better tyre is planned whilst I get the other car finished.
Posted 31st Mar 2015 at 21:47
