Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2
Lap of the 'ring
| Author | Subject: 044 pump killing engine |
pete_rallye
Seasoned Pro Location: Yorkshire Registered: 12 Dec 2002 Posts: 5,253 Status: Offline |
Post #126
Can't honestly see it being either. If the battery can turn the starter over its got enough juice to run a 044 pump for more than a second. My car has 2x044 pumps and 2x intank pumps running from a race battery, and even when it won't turn the engine over and I use a jump battery it runs fine, and thats with a tiny 50amp alternator. My money is still on the reg! ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #127
But it doesn't have time to over fuelas the 044 is on for a split second, I'm willing to give anything ago so thanks for all your advice |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
Post #128
Thinking reg aswell |
pete_rallye
Post #129
I don't think its overfuelling, I reckon the reg is locking up and cutting the fuel off completely! Have you got a standard 3 bar reg you could swap it for? Does the reg run fixed rate or is it connected up to give variable rate? ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
fatlapit
Post #130
No not true. My fan used to kick in a cut the car because of the current draw from the length of wire from the dash to the fan. if dta is like omex you need a minimum voltage or it will shut down. Hence why i have relocated the relays and redone my wiring.________________________________________ |
pete-gti
Post #131
Might sound silly but could it be bad earth tripping it out? |
fatlapit
Post #132
but why would the reg lock up??________________________________________ |
pete_rallye
Post #133
Because its knackered?! Lol, don't know but I do know that regulators can lock up if you give them too much on one side of them in one go. It wouldn't explain why it used to work and now doesn't unless it has gone faulty but I just can't see it been electrical if the batteries got enough juice to turn over a starter. Saying that, we had a problem with a race car that every now and again it would lose its map and start running really badly. Restore the map and it was fine. Turned out that the cable supplying power to the ecu was so small that when you revved the engine hard and everything was working flat out, the voltage supply was dropping to below 10v and the ecu was throwing a wobbly. We found that by monitoring the voltage on the ecus software. Might be worth a look? ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pugheaven
Post #134
Can't see it being a bad earth as all the leads are new, all farthing points are clean and bare metal as I used a rotary bonding brush to take all the paint off after the respray.I'll try another reg but I dont have one at the mo, hopefully rich will have all the spares I need! It's bound to be something simple and rich will find the issue straight away |
fatlapit
Post #135
I hope so bud cant wait to see her go________________________________________ |
pete_rallye
Post #136
fatlapit wrote: I hope so bud cant wait to see her go Think that goes for all of us! ________________________________________ Oulton Park in a BTCC 306 vid 1Oulton Park in a BTCC 306 vid 2 Lap of the 'ring |
pugheaven
Post #137
Thanks lads |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
Post #138
I can't see it being the reg... not much to go wrong inside them - it's only a spring really! I hope it's not - that reg is a special order Bosch motorsport part, and is around £250!Yes, I know there are cheaper 5 BAR regulators out there, but I didn't spare any expense ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
pugheaven
Post #139
Please don't be the reg, please don't be the reg, please don't be the reg..... At £250 I bloody hope it's not the reg lol |
rallyeash
Post #140
I don't think it's your reg. If it's immediate shut down it's wiring. Get the laptop onto the DTA. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
Post #141
Alternator and battery problem - just out of interest why are you running a racing battery ? |
Ben_W
Formerly gpm Location: Lutterworth Registered: 01 Sep 2007 Posts: 2,941 Status: Offline |
Post #142
rallyeash wrote: I don't think it's your reg. If it's immediate shut down it's wiring. Get the laptop onto the DTA. This. Shutting down immediately when you connect the other pump suggests a wiring/electrical issue with something. If it were the regulator, it would run for a few seconds whilst the fuel in the system is used up I'd imagine. I'd be trying a known good 044 pump to start with and rule out any electrical fault with that. It there anyway you can be checking voltage across the coils etc when it shuts down? It definitely sounds like something in the system doesn't like the 044 pump and the only thing I can think of that would kill an engine instantly is lack of spark.... Is there any of the std immobilser stuff still fitted? It's not that cutting in is it? ________________________________________ Cherry Red Rallye .... On going OEM spec restoChina Blue GTi6 .... Weekend toy Black 208 GTi .... Wife's car now Silver BMW 550i.... The executive missile |
rallyeash
Post #143
Run the 044 from a separate battery completely to the car. Including earth________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
pugheaven
Post #144
bigbadbowen wrote: Alternator and battery problem - just out of interest why are you running a racing battery ? Because race car lol in all seriousness it weighs half if not less than a standard battery and the dimma is all about saving weight If it was the pump would it not short out when both pumps are connected with out me trying to start the engine? Hope it's not the pump as I got it years ago and I can't see think automotive exchanging it even though it hasn't been used in the years iv owned it! I'll try all that has been suggested when rich gets back as like a few have said me/rich need to see what the dta is doing |
rallyeash
Post #145
Something is spiking the system and the ecu is protecting itself. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
pugheaven
Post #146
I don't think the standard immobilser is wired to the ecu and even if it was surely it would kill the engine with just the standard pump making the car run |
rallyeash
Post #147
Have you bench tested the 044 itself? ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
pugheaven
Post #148
No not as such, but I did disconnect the line to the rail , turned the ignition on with just the standard pump connected electrically and there was a slow flow of fuel, I then connected the 044 electrically and the flow increased dramatically so in effect I have tested the pump for correct direction of flow and pressure |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
Post #149
rallyeash wrote: I don't think it's your reg. If it's immediate shut down it's wiring. Get the laptop onto the DTA. Do you know how to look at the diagnostic screen on the laptop?. My old E48 can run the injectors and coil as a test, if you do that with the injectors unplugged, fuel will flow from the pump and just return to the swirl pot/tank. At least you will know that there are no electrical issues. Also when the engine dies instantly are both pumps still running for a couple of seconds after, like when it primes the fuel system?. |
Post #150
all you need to do is turn the ignition on, the ecu primes the pump each time you do that, and whenever it sees rpm it will run the pump.so yeah, get a laptop plugged in and it'll give you an idea of voltages etc. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
