Author Subject: Fitting Brembo's.
Nose
Hi guys, well got the phone call I've been waiting for, finally got hold of some Brembo's. I know this question has probably been covered 100000 times, but I can't find a guide Crazy I know I need 288 Xantia discs, but what else is needed please boys? I do want to keep the Cyclones by the way.
cheers Thumbs up
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 20th Mar 2015 at 20:14
big f**koff spacers, and longer brake lines.
Posted 20th Mar 2015 at 20:26
aaron6
As welshpug said, big spacers. 20mm.
This will also bring your tire into contact with the arch whilst cornering or over a big bump.
Posted 20th Mar 2015 at 21:33
Nose
Sorry to bang on boys, but do they just bolt straight on then or is there a bracket required also?
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 21st Mar 2015 at 10:18
Rich E Forum Admin
Assuming you mean 406 Brembos then they bolt straight on yes.
Posted 21st Mar 2015 at 10:41
Nose
Yes Rich 406 ones, excellent matey - good to know.
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 21st Mar 2015 at 10:56
marco gti6
When installing them make sure the bleed nipples face upwards. I read on the french forums that this would prevent them from squealing. Apparently it has something to do with having the big piston facing down or something like that...
Posted 21st Mar 2015 at 12:25
aaron6
Hmmm... I may try that.
Posted 21st Mar 2015 at 13:11
never seen anyone fit them upside down, they still squeal.
Posted 21st Mar 2015 at 13:19
aaron6
Worth a try for the small amount of time it takes to fit.
Posted 21st Mar 2015 at 13:21
marco gti6
I was told so by few folks on the french forum. Apparently some were fitted upside down on the 406 V6 on the production line. Also the 406 V6 calipers are still used as the gravel/dirt brake setup on the C2R2 for example.
Rather this is true or not, i can not confirm, but some french members say that their setup is silent
Posted 21st Mar 2015 at 14:28
100% can confirm this LOL
When I had mine tried that !!!!.......Mei your correct still squealed like a B-tch Thumbs down
Tarox drilled Discs made the most difference but still a bit of Squeal .....
Posted 21st Mar 2015 at 14:32
Mossy1985
When i fitted these to my 106 they squeeled like a bas**rd! I tried everything from taking the alloy plates off inside the caliper and cleaning to allow the pads to move easier, to putting disc squeel stop on the back of the pads to different disc off sets etc etc and bugger all worked
Posted 21st Mar 2015 at 14:38
yes they certainly are, they still squeal like f**k LOL possibly not as much as they use very aggressive pads that do munch away at the discs
Posted 21st Mar 2015 at 14:51
Nose
So what actually causes the squeal then Mei? Is it pad material?
Bianca 306 Rallye.
Mondeo Titanium X.
Posted 21st Mar 2015 at 21:40
osm2121
It´s actually quite simple, set has wrong offset. Xantia disc, will sit aprox 1.3mm outwards from the center of the caliper, where theres only about 1.25mm gap between disc and caliper. First the disc will "file" down the caliper, and will be always totally out of place.
You can read and check the pictures here: http://www.306gti6.com/forum/showthread.php?id=162232
Posted 31st Mar 2015 at 18:50
aaron6
So if I put the disc up in my lathe and machined 1.30mm off of the inside mating face, your saying it won't squeal? If that's the case, I'm willing to try it.
Posted 31st Mar 2015 at 20:49
osm2121
I wouldnt machine off the inside of the disc. It only has about 6mm. But you can trim down that difference on the caliper, where it sits on the hub. I´m no t sure that´ll solve the squealing, havent tried it yet, but who knows.
What I mean, is that its not exactly a direct fit 406 Brembos + 288x28 discs.
As soon as I try that, i´ll post the results. But anyways, that´ll surely improve, as the disc will sit where it´s supposed to.
Posted 2nd Apr 2015 at 01:24
