Author Subject: Hub refurb
So I decided to refurb a set of 18mm hubs even though bearings felt ok. I managed to push the hub out the bearing then found a dry set of ball bearings inside the actuall hub carrier.
Getting the remainder of the bearing out was fun but seem to have the nack now
Will tidy up the whole lot then paint them both and install a new set of sky bearings and febi hubs (both are not cheap) will upload pics once looking nice Thumbs up
I can maybe do this on exchange basis if anyone is interested ? Be warned bearings and hubs are pretty pricey Yes
Posted 11th Mar 2015 at 18:42
barrym
That they are. Cost me £130 to have the old bearings pressed out and new ones pressed in . That was for the pair with me supplying the bearings.
Circlips snapping adds to the man hours, was 3 in my case, and needing to exceed the 10 tonne press rating adds up to dollars
Black Rallye occassional toy
Posted 11th Mar 2015 at 18:50
That's pricey I assume they had to take them off the car ?
Bearings and bus come in around £100 ish for both sides and I had no trouble getting the old sir lips out or pressing bearings out ?
For just labour I'd clean the hubs (wire rotary brush on a grinder) and paint them for £130
Posted 11th Mar 2015 at 19:00
barrym
no mate I took the hubs to them off the car. They were a nightmare for them though. The circlips snapped, one of them twice. And we were all stood hiding round the corner while the apprentice pumped the handle on the press to get the bearings out. We didn't half jump when they came loose with an almighty BANG!
As said it took them a good 3 hours so £130 is pretty good. Plus I know them and know no hammers were involved which is worth quite a lot to me.
Posted 11th Mar 2015 at 19:08
I did well then with a 12 ton press hubs poped out fine and bearings only put up half a fight
Posted 11th Mar 2015 at 19:16
rallyestyle
Would have loved to have seen a video of the press in action Yes
Just Drive It
Posted 11th Mar 2015 at 19:33
It's not that exciting dude I takes longer to prop the hubs up than actually pressing out the bearings . Getting the ones back in might prove a bit harder
Posted 11th Mar 2015 at 19:40
cully
cleaned my hubs with electrolysis before attempting to remove anything once clean the clips bearings and sensors came out quit well Wink
Posted 11th Mar 2015 at 19:44
Mossy1985
Ive just done mine, getting the circlips out was a pain but once i got them out i soaked them in wd40 over night and then my 15 ton press made short work lol
Posted 11th Mar 2015 at 20:08
I can't get the abs sensors out so they will have to stay in
Posted 12th Mar 2015 at 11:12
pugheaven
I did this with the dimma hubs but got them powder coated! Like you say wasn't cheap but now look the tits and are minty fresh Smile
Chris, powder coat them! Lot better than painting them
Posted 12th Mar 2015 at 11:21
pugheaven
Posted 12th Mar 2015 at 11:28
cully
mine in primer before the top coat
cooking away in the electrolisis tank
[/URL]
Posted 12th Mar 2015 at 13:21
Pressing the hub out the middle is a doddle. Hardly takes any force if you do it straight with the right tool. However the bearings can be tight as f**k on 306's Had to heat the bollox out of the last one I did from a phase 1 was properly seized in. Replaced the old press at work with a 50 tonne one end of last year. Most things come out without to much trouble now LOL
Posted 12th Mar 2015 at 13:44
Trying to keep costs down so rattle can is the way forward as I have loads at work after all no one will see them. How did you get the abs sensors out without f**king them up ?
Posted 12th Mar 2015 at 15:23
cully
once the hub was clean i tapped them out with a socket and hammer,
find a socket that just fits over the magnetic tab and tap it to push the sensor out,
think i used a deep 3/8 drive 10mm socket reversed so the sockets 3/8 large surface area was against the plastic of the sensor
Posted 12th Mar 2015 at 15:41
pugheaven
If you do it in bulk and use the right company powder coating will be cheaper, less prep work and time is money
Posted 12th Mar 2015 at 16:04
