Author Subject: Who's clued up on S16's?
stepup
I'm going to get my S16 out of the garage after a 3 year sleep.
Want to do a few bits, oil change, clutch cable and cambelt etc.
Just need to know how much of it is the same as Gti6 like cambelt etc?
Also would be nice to know whos good to ask any future questions rather than bog down your forum with threads filled with my lower class s**tbox.
TIA. Rob
owain wrote:
Twisties are for those with balls, top speed is for those with tiny little penises.
SCIENTIFIC FACT.
Posted 10th Mar 2015 at 10:13
timing belt kit is different, block and crank, most seals and the filters are the same, rest is not.
plugs the same actually.
Posted 10th Mar 2015 at 14:34
just PM welshpug above regardless of what you need. if you don't hear back within an hour, resend the message Yes
Whistle
nowt wrong with the s16, had an xsi with an s16 engine in, decent lump when the acav is working properly
Posted 10th Mar 2015 at 14:39
stepup
Cheers for the replies.
Welshpug... looks like youve been nominted Wink
Best place for cam belt and pump kit? (Not going stealership)
SCIENTIFIC FACT.
Posted 10th Mar 2015 at 16:22
ad
TIA. Rob
I had an s16 for 8 years and was my pride and joy until someone wrote it off in May last year. I thought the cambelt was the same as the gti- 136 tooth, same water pump, same tensioners, pretty sure it was when I had it changed. They are basically the same as a gti in "most" departments apart from engine.
Edit...it has 134 tooth belt,
ad has attached the following image:
Posted 10th Mar 2015 at 18:55
Looks nice mate, my first quick 306 after a string of diesels was a Sigma blue S16 with a GTI-6 engine conversion was minty mc mint never should have sold it.... Did the clutch and heater matrix etc. I'm partial to a black car and my current blak 6 of 7 years came up silly cheap so I sold the S16 and bought the 6...
No idea what happened to it and if you type the reg in on DVLA it says it's not recognised so it obviously had a plate change after my ownership.
Posted 10th Mar 2015 at 19:26
Might as well try the dealers. I'd speak to ed or steve at warners Peugeot in Tewkesbury and say I sent you off this forum - 01684 297575.
Get a water pump too. May only be £10 more than your local factor but at least you know the pump is original quality. Think it worked out at £12 more for the last gti kit I bought, all discounted as I'm trade
Posted 10th Mar 2015 at 19:58
Yup I just got a genuine 136kit and water pump from KAP in Eastbourne and with decent discount was same prices I could get factors parts for.
Posted 10th Mar 2015 at 21:30
