Author Subject: dturbo / hdi crank & rods with std gti6 pistons?
rhyds
it is do able albeit grinding the crank?
i'm assuming then there will be a slight increase in cc from the 1998 standard?
Posted 6th Mar 2015 at 13:22
cully
little end on the rods differ i believe
HDI gudgeon pin is cir-clipped maybe a different diameter too
i may be wrong
Posted 6th Mar 2015 at 14:08
rhyds
what about d turbo?
if i used the dturbo / hdi pistons as well would that work?
Posted 6th Mar 2015 at 14:15
cully
info from here no mention on little end diameter though
http://www.christiantena.pwp.blueyonder.co.uk/motor/peugeot/hdi/b1bbm2k3.htm
CRANKSHAFT
DW10 ATED engine :
crankshaft (identical to XUD9TE engine)
in burnished steel
with 5 bearings
DW10 TD engine :
crankshaft (identical to XUD7TE engine)
material : steel
with 5 bearings
CONNECTING RODS
New connecting rods (145 mm between centres) (Identical to DW8 engine) :
forged steel connecting rods
the little end is fitted with a machined bronze bush in the shape of a snake's head
Posted 6th Mar 2015 at 14:25
cully
little end for the DW10 28mm according to that site
Posted 6th Mar 2015 at 14:30
cully
dw10 barrels are 85mm XU10 is 86
Posted 6th Mar 2015 at 14:40
rallyeash
88mm 1.9 XUD crank, 86mm S16 rods and pistons. Pistons pocketed to get some decent cams fitted. Job jobbed. 2044cc
309 3dr K20 Type R
Posted 6th Mar 2015 at 18:53
eddy_gti6
Thats if you can find a set of S16 rods and pistons!
Posted 6th Mar 2015 at 19:38
rallyeash
Yeah don't know of any I'm afraid.
309 3dr K20 Type R
Posted 6th Mar 2015 at 19:42
allanallen
Think I've got some, could pocket them too....
Facebook
Posted 7th Mar 2015 at 07:32
