displaying posts 1 to 25 of 35
Author Subject: rich w wishbone bush replacement
Mossy1985
Bought myself a set of rich w roller wishbone bushes that need fresh bearings fitting. I was wondering what the bolts are for that stick out of the p bush housing? They have washeres underneath them? Also has anyone who has done a bush replacement before got any tips or is it straight forward to do?
Posted 3rd Mar 2015 at 20:55
chiefton
Is'nt it a grease nipple? Was when i had a set of them
cherry rallye daily (the money pit)
Posted 3rd Mar 2015 at 21:04
Mossy1985
There are nipples yes but im talking bolts. I will grab a pic and put it up in a min
Posted 3rd Mar 2015 at 21:26
Mossy1985
These are the bolts i mean
Mossy1985 has attached the following image:
Posted 3rd Mar 2015 at 21:47
eddy_gti6
If its the one on top of the bearing thats where you bolt it through the subframe and the big one goes through the subframe and ARB bracket
Posted 3rd Mar 2015 at 21:53
Mossy1985
That one ^^
Posted 3rd Mar 2015 at 21:49
eddy_gti6
Through the subframe. Whats your plans for your 6? Seen it the other day when i was passing
Posted 3rd Mar 2015 at 21:54
Mossy1985
Well i have bought another engine with cams and mapped ecu, got a gearbox with quaife, jord rebuilt rear beam with 21mm bars, full b8 set up, baker b m solid beam mounts and group n engine mounts, vts 2.4 rack, seam welded subframe, lightened flywheel and crank pulley, adjustable drop links, c5 steels, braided brake lines, miles linkages, GE quickshift, PTFE inlet gasket, phase 1 seats and roller bearing wishbones
Posted 4th Mar 2015 at 07:28
Mossy1985
I also have new bottom arms, track rods, track rod ends, bottom ball joints
Posted 3rd Mar 2015 at 22:01
cully
no wonder i cant find no spares as your buying them all Razz
nice list
Posted 3rd Mar 2015 at 22:52
chiefton
Ahh yes i misread lol,it goes through the subframe,think it stops it twisting etc etc
Posted 3rd Mar 2015 at 22:54
chiefton
Niiiiice collection of parts also lol Thumbs up
Posted 3rd Mar 2015 at 22:55
Mossy1985
Mossy1985 wrote:
nice list
Big grin cheers cully, my loft is getting a bit rammed now like. I have started doing bits and pieces like ive had the diff out and replaced bearings and seals and painted the box. Ive stripped down a pair of hubs i bought and painted them and put new bearings in etc. Im taking pics as i go and i plan on doing all the work on the actual car in a 4 day window. Once its complete i will put up a full thread for those who are interested with as many pics as i can take
Posted 4th Mar 2015 at 06:57
Chr1sch
I could probably do with replacing my richw's too - i.e. the innards, is it only Rich directly that provides these?
Posted 4th Mar 2015 at 09:46
cully
how did you clean the hubs up before painting?
when i did mine i used electrolisis to clean them back to like new before painting
Posted 4th Mar 2015 at 09:53
Mossy1985
You obviously did a proper job cully. I just emry papered and wire brushed to get the thick off. Ive bot painted for looks just to try to get a bit of protection for them
Posted 4th Mar 2015 at 10:00
cully
dont need to sand them once theyve been through the electrolisis tank
just wash them off wire brush then paint Wink
Posted 4th Mar 2015 at 10:05
Mossy1985
So if i need anything doing i should send it to you Smile im a far cry from walter white when it come to chemistry
Posted 4th Mar 2015 at 10:32
eddy_gti6
Wire wheel on a grinder works wonders Wink all i ever use when i clean stuff like that.
Dave why dont you start a project thread then you can update your progress as you go Thumbs up
Posted 4th Mar 2015 at 10:36
Mossy1985
I intend on doing one when im done Chris purely for the reason of i dont own a computer and uploading pic after puc on my phone would be a pure ball ache. My plan is to take a load of pics as i go and then transfer them onto my mams laptop and then do a thread where i can actually ise a proper keyboard lol
Posted 4th Mar 2015 at 10:49
aaron6
With regards to changing the bearings, take them out, measure them up and go to a supplier and buy them. It'll be pretty cheap. I also don't understand the need for open bearings and greasing them. It just allows road grime to get in. Why don't people replace with ZZ steel covered or RS rubber sealed bearings?
Posted 4th Mar 2015 at 13:23
Mossy1985
With hindsight maybe that would of been the way forward but i have already bought the replacements from Rich now so i may take the new ones to a supplier and see if they offer a similar item with more protection as you say
Posted 4th Mar 2015 at 17:53
aaron6
I would. From what I've seen there is no s**t guard and road s**t just builds up in the grease.
Posted 4th Mar 2015 at 18:18
rich_w
The bearings are sealed...
Contact Details:
07732 822546
Posted 6th Mar 2015 at 21:51
Mossy1985
Yes Rich now i have recieved the bearings i see how they are designed
Posted 6th Mar 2015 at 21:57
