£0
1999 Peugeot 306 GTI
  • 2000cc
  • Black
  • 134 miles
  • No tax
  • No MOT
  • Some service history
  • Cambelt changed: Jul 2012
Modifications: Bilstein B12 suspension kit (Eibach front springs) Rebuilt rear beam, lowered 30mm Baker BM solid rear beam mounts Mocal thermostat sandwich plate, unknown brand 13 row oil cooler and braided steel lines Mongoose stainless cat back exhaust OMP front upper strut brace After market air filter with cold air feed pipe Constella group N gear linkages
Contact: 07891238088
displaying posts 1 to 2 of 2
Author Subject: 1999 Peugeot 306 GTI
mtp
Peugeot 306 GTI
T reg 1999
134,000 miles
3 former owners
MOT expires March 2016
Service history
Peugeot OEM Dayco cambelt kit and water pump fitted at 111,132 miles (22/07/12)
New crank damper pulley and aux belt fitted during cambelt change
New NGK lambda sensor fitted at 124,315 miles
New clutch fitted at 85,117 miles
Service book stamped up to 85,000 miles (independent specialist servicing)
Every MOT certificate from 2007 to present, I don’t have any pre-2007 certificates.
Modifications
Constella group N gear linkages (only the shortest linkage is fitted at the moment as the original OEM one broke, the 2 longer linkages will be supplied but are not fitted, they have never been used).
Bad points
Dent on rear offside corner (see pictures). Some paint damage, no rust, bumper is still secure.
Worn drivers seat base
Air con doesn’t work
Other points
Bridgestone Turanza tyres, plenty of tread
EBC Yellow stuff brake pads
2 keys
Now sold
Posted 8th Mar 2015 at 14:45
mtp
SOLD
Posted 8th Mar 2015 at 14:46
