Author Subject: Coolant temperature sensor plug
Is it possible to buy new sensor plugs (the bit thats on the engine wiring loom and connects to the green coolant temp sensor).
I stripped the teeth off my starter a couple of weeks ago so had to put the standard one back on, i guess i must have somehow damaged this plug when faffing about as part of it is now broken. Now my car seems to be running like crap as the plug keeps coming off at random and i want to get it sorted.
Also, would this cause the radiator fans to be constantly coming on and off? I have had a search and thought that this green one was only for the engine ecu so it would make sense that it runs awfully and is hard to start when warm, but i thought the brown one would be the cause of the dodgy fans, which seem to always be running at low speed with the engine now. High speed fans still kick in when unplugging the brown sensor or turning the a/c on.
Posted 28th Feb 2015 at 15:20
oldbrownshoe
10$
http://www.aliexpress.com/item/1338A-Water-Temp-Temperature-Sensor-for-Peugeot-106-206-306-307-406-407-607-1007/32290820581.html
French military victories?
Did you mean French military defeats?
Posted 28th Feb 2015 at 15:46
Thanks, it's the plug that's on the engine loom that I'm after though. Smile
Posted 28th Feb 2015 at 15:52
oldbrownshoe
then look for the right one here.
Posted 28th Feb 2015 at 16:36
jorg
they are just junior power timer plugs which you can pick up on ebay for not alot of money Yes
i have been using http://stores.ebay.co.uk/Brands-Hatch-Performance for most of my stuff at the moment
306 2.1 S16 Tarmac Rally Car
Posted 28th Feb 2015 at 16:55
Thanks guys. Thumbs up
Posted 28th Feb 2015 at 17:12
