Author Subject: diff pre load
pete-gti
Right just to clear things up as my head bit confused about it. , I've heard some come with shims some didn't?
Mine didn't have shims fitted
Been told pre-load on the diff bearings is done by the speedo housing. I've done up the speedo housing to what I thought the torque should be
But is there a special way to do this?
Colin at pug performance He said all the boxes he has done there has never been a shim. He said just make sure the diff turns when its all together and that there is no end float and if theres non then you are all good??
Posted 28th Feb 2015 at 13:27
Just about only job I've never done yet but my diff will be here this week. If there wasn't a shim it can't have needed one so wouldn't worry personally. As long as you put it back how it came apart I can't see there being an issue.
Posted 28th Feb 2015 at 13:52
No shim needed in either of mine, conical bearing surface so the speedo housing does the tension
Posted 28th Feb 2015 at 14:58
Exactly. Effectively like doing up a taper wheel bearing.
Posted 28th Feb 2015 at 15:27
pete-gti
What's the speedo housing torque?
Posted 28th Feb 2015 at 16:51
Pass lol probs 20nm ish at a guess? Can look on autodata but not till monday...
Posted 28th Feb 2015 at 17:45
Mossy1985
If you could rhat would be great as im building mine up on tue
Posted 28th Feb 2015 at 18:17
Had a look on autodata and it doesn't specify a torque for the speedo housing anywhere.... Even went into repair times for speedo housing and it have time but no special instructions. Las one I replaced I just nipped hand tight to a sensible amount and never had a comeback at all.
Posted 3rd Mar 2015 at 10:21
