displaying posts 1 to 25 of 30
Author Subject: diff housing seals
Mossy1985
Hi guys I'm just after some advice if possible. I've got a gearbox that im fitting to my 6 and i thought I would clean it up and paint it before I fitted it. So I was looking over it today and I noticed that the seals on the diff for the driveshafts, well there looks like there is only one? On the first pic you can see the seal no problem at all. However on the 2nd pic there seems to be just a metal bearing housing as it appears but it's flush with the end of the causing? Is there ment to be a seal on the other end as service box does lists two seals with two part numbers so the 2nd seal may be a completely different looking item? Does the 2nd seal sit inside the metal housing? Any help at all is appreciated as always
Dave
Posted 3rd Feb 2015 at 15:11
you're not just missing the seal, you're missing the whole speedo drive housing which holds the bearings in as well!!!
if its a 6 speed box you may well be missing a shim too.
Posted 3rd Feb 2015 at 15:14
Mossy1985
Can I take this from my old box or am I going o have to take this to transmission specialist?
Dave
Posted 3rd Feb 2015 at 15:16
your old one should do the job.
Posted 3rd Feb 2015 at 15:21
Mossy1985
On the 2nd pic where I'm assuming the speedo housing goes, there is no shim stuck to the bearing, so I take it the shm sits between the bearing and the speedo housing yes? And it's the speedo housing that holds the other seal?
Posted 3rd Feb 2015 at 15:25
correct yes.
Posted 3rd Feb 2015 at 16:49
Mossy1985
Thumbs up much obliged
Posted 3rd Feb 2015 at 19:52
Shim sits in the diff housing - speedo drive housing attaches to the diff housing
Posted 3rd Feb 2015 at 20:00
Mossy1985
So of we look pic number 2 then will the shim sit on top of the bearing race? Ie the part with the numbers stamped onto it? Or is it the next circle out ie the actual casing itself?
Posted 3rd Feb 2015 at 20:21
Unless diff housing has been opened the shim can't come out ? It sits next the roller bearings on the diff it's self ? Open up the diff housing and check there is a shim for each bearing on the diff - I learnt the hard way what happens if they are missing
Posted 3rd Feb 2015 at 20:44
Mossy1985
The housing has been opened at some point so I will open it up again and make sure they are there then. Are they just a certain thickness? Meaning as long as there are two shims in there it should be ok?
Posted 3rd Feb 2015 at 20:50
it'll only have one.
Posted 3rd Feb 2015 at 20:56
Mossy1985
Service box does only show one shim (if I'm looking at the correct picture ofcourse)
Posted 3rd Feb 2015 at 21:00
what's the bit of metal that the diff bearings sit in then ? Race bearings ?
Posted 3rd Feb 2015 at 21:20
Mossy1985
Yes mate the part with the numbers stamped on it in my 2nd pic is the bearing race (or cup if you like). It's what the roller needles run around on
Posted 3rd Feb 2015 at 21:34
pete-gti
Here few pictures might help
With housing connection
Posted 3rd Feb 2015 at 21:43
Mossy1985
Cheers Pete, I'm now wondering if i should just open mine up, renew the bearings and make sure I have the shim in place?
Posted 3rd Feb 2015 at 21:48
pete-gti
Might aswell want hurt :-)
Posted 3rd Feb 2015 at 22:09
Mossy1985
Would you know where I could buy some bearings? A users name on ebay perhaps?
Posted 3rd Feb 2015 at 22:12
pete-gti
Just sold my last pair Sad but yea eBay :-) or any bearing company
Posted 3rd Feb 2015 at 22:24
I've got some spare from when I rebuilt a box but used an LSD that already had some fairly recent ones fitted if you're after some.
Posted 3rd Feb 2015 at 22:57
Mossy1985
I've got some spare from when I rebuilt a box but used an LSD that already had some fairly recent ones fitted if you're after some.[/quote
Drop me a pm Thumbs up cheers]
Posted 4th Feb 2015 at 06:32
Mossy1985
Just priced 2 seals from the stealers and a set of engine mounts and the seals are over 30 quid! Ebay is calling my name i think
Posted 4th Feb 2015 at 08:59
Check your local motorfactors, mine does febi driveshaft seals at about £7 a pair.
pm sent re- diff brgs.
Posted 4th Feb 2015 at 09:04
Mossy1985
Rang my mate at motor factors and got some febi ones for 8 quid, numbers direct match from one number, cheers Mei
Posted 5th Feb 2015 at 08:55
