Author Subject: Quickshift whyg on yours?
Mossy1985
Wanting to fit a quickshift to my 6. I read a few posts on here and the net and plumbed for a £20 GE item. Well it has arrived and even though I am yet to fit it, it feels extremely light and small but somehow not in a good way. I was wondering if many people on here have these fitted and if so do they like them? And if not one of these what have you got? I've just looked at the Ecosse version which looks a completely different design. Apart from Hesse 2 are there any other gearbox end quickshift s available? As I've given up on a satchshift lol
Cheers all
Dave
Posted 15th Jan 2015 at 15:31
i had a GE quickshift and it was great. some people whinge about the balljoint / it working loose but i can only put this down to them being pansies with how they tighten it
ps "whyg" reminds me of ebay people
SUBARU 2.0 GL 1994 NOT IMPREZA WONT SWOP WINK WINK WHYG
Posted 15th Jan 2015 at 15:34
Mossy1985
I don't even know why I put that as normally I'm not that lazy lol but cheers for your thoughts on the GE I've bought it now so I will fit it and see how it fairs. Will just locktite the ball joint into the main body and give it a good nip
Posted 15th Jan 2015 at 15:45
i also had a skip brown one which basically they make in situ, by extending the ball out on the subframe selector bit. that was just as good, but dearer than £20
Posted 15th Jan 2015 at 15:57
chiefton
Iv got ge engineering one never had any trouble and was great then added compbrake short shift turret at the gearstick and its awesome with the both.
Worth the 20 all day long id say for ge one!!
cherry rallye daily (the money pit)
Posted 15th Jan 2015 at 16:01
Mossy1985
Cheers chiefton good to no
Posted 15th Jan 2015 at 16:12
nothing but some of miles' linkages.
Posted 15th Jan 2015 at 17:06
ZX gearstick is shorter at the top, so its a shorter throw anyway Big grin
Mossy1985
Who is miles? Is he on the forum? Zx shorter you say Smile
Posted 15th Jan 2015 at 17:35
Mossy1985
Is that all models or just 16v?
Posted 15th Jan 2015 at 17:36
all the same Smile
Posted 15th Jan 2015 at 17:54
I did away with my GE quickshift found it to make the gear change too Notchy. Particularly on a box that's done 145k. I've now just got uprated linkages from miles with a cut down gear lever for shorter throw and it's spot on.
Also I got my GE quickshift second hand from someone claiming it slipped so they took it off.
Before I fitted it I drilled out the piddly bolt holes and put a larger bolt through instead and it need moved a mm once fitted.
Posted 15th Jan 2015 at 18:03
hampstead
A previous owner had put a Skip Brown shift on the first Rallye I had. It was great, the throw was reduced and there was no notchiness. The receipt in the service history was for about £55 but I think you have to go to them to get it done. I would love one for my current car but Cheshire's a long way from here!
I don't remember any difference in the precision of the shift between that car and other 306s - if your gear change is imprecise could the linkages be knackered, engine or gearbox mounts shot, cup cracked, etc.?
For uprated linkages, Miles is the guy's forum name, his website is pugracing.com
Shorter lever is a good idea as well, did you fit a ZX one or make your own armzs?
Matt
Posted 16th Jan 2015 at 23:10
I used the standard 6 one and cut it down also made a guide on here should be able to find it easy enough
http://www.306gti6.com/forum/showthread.php?id=157275
Posted 17th Jan 2015 at 21:25
