Author Subject: Castor Angles
Hawkesfire
Hi
I am currently rebuilding my 206 rally-cross car with a GTI6 SHB engine and want to pick someones brains on suspension as i have removed the inner wing as i will be adding strut tops from the cage and then tubbing in the front arches for clearance when i run it low on 17" rims, i have also removed the front sub-frame and manufactured one out of tube so that i can install my own fabricated rose jointed bottom arms
My question is what is the best castor angle to run as i see some of the new rally cars running huge castor around 12 deg and i have power steering so wont have the issue of heavy steering
Anyone got any advice on whats best to run???
Marty
206 Rallycross GTI6 SC SHB 425 BHP clutch eater !!!
Posted 13th Jan 2015 at 08:10
I am no expert at all so disregard what I have to say but I got told of somebody that was to run as much as possible
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 13th Jan 2015 at 10:22
Ask Colin Satchell, I doubt he will divulge all his chassis setup data but might be able to give a pointer.
Those rally cars running big castor also dont have the damper running directly to the lower pivot, often some way in front and very long travel, and very expensive roller bearing units, not bushed.
Posted 13th Jan 2015 at 12:44
