displaying posts 1 to 1 of 1
Author Subject: rear window heat fault..
Bobeek
Probably many of you had this problem before cause its quite common...
Bought my rallye and noticed the heater of the rear window is not working..there is power on the switch (light) and when pressed it I could hear the relay "clicked"..happened before with my other 306, its a relay problem..little bit of soldering and the heater is working again! Smile
1st pic-clearly see the sign of a bad contact
2nd-3rd - no contact at all between the "leg" of the relay and the pcb..
Posted 24th Dec 2014 at 21:09
