Author Subject: Problem in removing the Bitron control unit ZX16V
oldbrownshoe
It should be peace of cake, after removing the wheel arch cover,
there is only 2 10mm bolts that secure it to the body to be free,
but it turned out to be nightmare,
i've loosen the bolts completely but it won't came off.
there is no access to the other side, it's double sheet metal that the ABS unit is located just above it,
anyone experienced this kind of french resistance ?
French military victories?
Did you mean French military defeats?
Posted 23rd Dec 2014 at 09:45
its not double thickness if it is under the abs pump.
are the nuts off and the pluf? just get a big screwdriver under it.
Posted 23rd Dec 2014 at 12:15
oldbrownshoe
I meant it's on the same axis, there is some space between them,
but some mechanic told me that there is nuts on the other side, which i don't understand/believe
if so, it's only good for one dismantling, even Citroen engineers couldn't be so dumb,
anyway, i wanted to salvage this unit for the ZX reflex, but it turned out to be different unit part numbers,
so i gave up this rout, and just buy a used one,
the reflex is much more sensible design and easier procedure since it uses nuts on the open side instead of bolts
Posted 23rd Dec 2014 at 15:06
Chr1sch
that sounds weird, sure its the bitron?
Mine is held on with 2 (i thought 8mm) nuts on inch long thread - there isnt anything else holding there, but there is a metal colar thing in each wing of the bitron body, could just be stuck/corroded on?
Posted 23rd Dec 2014 at 15:14
oldbrownshoe
The bolts turns freely in my fingers but refused to come off,
i even grabbed it with vise grip pliers, i attached the second to the first in 90 degree so i could
strike it with a hammer, but it still refused to come off.
yes, i'm sure it's Bitron that is the part for the reflex :
9622150680 / CCTC6 / BVM2
and it's used in 106, 605,406, saxo, xantia, evasion too
Posted 23rd Dec 2014 at 15:35
Chr1sch
hmmm interestingly i did find that the thread on the bar is very fine and one of mine has stripped, could you have done the same?
Posted 23rd Dec 2014 at 16:02
oldbrownshoe
It could be, but in the first time i didn't feel i destroyed it,
but later when i tried to screw it it remained free.
i can't tight it no more
Posted 23rd Dec 2014 at 17:02
oldbrownshoe
I've got for a test a new Bitron and it the fans still won't work.
any ideas ?
Posted 24th Dec 2014 at 13:44
