Author Subject: supercharger oil cooler
pugheaven
Does anyone know what size the fittings are on the oil cooler? I think it's a 10 row cooler but need to know what thread size they use!
Posted 15th Dec 2014 at 14:47
pugheaven
Any one???
Posted 16th Dec 2014 at 23:38
Ask rich
Posted 17th Dec 2014 at 09:02
ask whoever supplied the cooler, or measure it.
Posted 17th Dec 2014 at 09:08
pugheaven
I don't know who supplied the cooler and I can't measure it as the old hose fittings sheared the fittings on the oil cooler
Posted 17th Dec 2014 at 11:16
so your cooler is fooked anyway then?
Posted 17th Dec 2014 at 11:28
pugheaven
I would imagine so with sheared fittings..
Would be good to have the same thread size as before!
I know your going to say it doesn't matter as I can order a new cooler and fittings for an 11mm id hose however I want to keep with the original spec so it's the same as everyone else's
Posted 17th Dec 2014 at 13:28
order whatever is most common, that's probably what everyone else uses anyway.
Posted 17th Dec 2014 at 14:02
aaron6
1/2" BSP usually.
Posted 17th Dec 2014 at 14:40
Nope their much smaller think they have adaptors from 1/2" bsp down to something half the size.... Think it's a 9 row cooler can check If you want but don't have a decent thread gauge here to check the rest for you...
Might be in here but I doubt it...
http://www.lynxpowerengineering.co.uk/sckitguidelines.pdf
Posted 17th Dec 2014 at 15:12
pugheaven
I "think" it's a 10 row cooler with 1/2 bsp fittings that are then stepped down to an8/jic 8 fittings as the hose is 11mm/ 7/16!
Posted 17th Dec 2014 at 16:11
If its of much use to you i can take a look when im back home on sunday?
Posted 17th Dec 2014 at 16:24
aaron6
Armz, measure the thread diameter and I'll tell you what it is while I'm here with my zeus book. I didn't realise they stepped down.
Posted 17th Dec 2014 at 16:26
aaron6
Infact, all the information you need will be here.
Posted 17th Dec 2014 at 16:30
pugheaven
A Zeus book is not much help.... We know that the fitting is smaller than 1/2 and I can't find any coolers that have a smaller take off than 1/2"
The I.d of the original hose is 11mm or 7/16 which is an-8 which you can get a step down from 1/2" - an8
Posted 17th Dec 2014 at 18:04
aaron6
Surely they will step down to a bsp thread. It's probably stepped down to a 3/8 BSP or 1/4 BSP. The zeus book charts for Armz to measure what his steps down too.
Posted 17th Dec 2014 at 19:20
pugheaven
You would assume so but I can't find any 3/8 fittings on eBay and no way would it be 1/4 BSP it's way too small!
Posted 17th Dec 2014 at 20:45
aaron6
You can the hoses made anywhere and they'll supply the fittings for peanuts.
Posted 17th Dec 2014 at 21:03
pugheaven
I'll make the hoses my self I just didn't want to have too smaller fitting and restrict the oil flow, I think if I use the same I.D hose as standard which is 11mm so 7/16" which is the same as AN-8 hose I can then get a 10 row 1/2 BSP cooler with step down to AN-8. Job done Smile
Posted 18th Dec 2014 at 00:08
aaron6
That don't sound a problem. Hope it all goes well fella. Just check the hole diameters in the fittings are not too restrictive and you should be onto a winner. Smile
Posted 18th Dec 2014 at 10:28
pugheaven
Just spoke to tts and apparently the cooler is a 10 row -6 jic fitting!
To double check I had a look at my new filter and it's got 5/16 written on it so that would tally up with the -6 fitting Smile
Time to spend more money Sad
Posted 18th Dec 2014 at 10:57
aaron6
What a stupid old skool thread choice. I'm a toolmaker and have never machined that thread. People nearly always want BSP or NPT. Well, at least you now know mate.
Posted 18th Dec 2014 at 12:20
pugheaven
It's because most aero fittings are jic/an so it makes it easier to make your own braided lines up
Posted 18th Dec 2014 at 12:33
aaron6
Well that kind of makes sense.
Posted 18th Dec 2014 at 12:44
