displaying posts 1 to 25 of 31
Author Subject: clonk when turning right
cornish_pug
Hi
I always get a single clonk when turning right, anything more than a 3/4 turn it happens.
It comes from the left side under the floor.
I changed my arb bushes thinking it was them but it still remains. Nothing obvious when up on axle stands just a slight clonk from the strut.
Any body got any ideas on what it could be?
Team Diesel
Posted 14th Dec 2014 at 17:15
pug_306
Sounds like a broken spring possibly
1992 205 GTi6
205 Turbo 340bhp
Posted 14th Dec 2014 at 17:17
lj_6
Could be the spring not seated or the rubber cover on the spring damaged. Causing it to move on the seat.
Astra burg #365 Garrett Power
'99 bodied 6 track project
Posted 14th Dec 2014 at 17:29
cornish_pug
Thumbs up I'll check these
Team Diesel
Posted 14th Dec 2014 at 17:32
scotzman
Top mount bearingYes
Posted 14th Dec 2014 at 18:52
cornish_pug
Did top mounts about 18 months back
Team Diesel
Posted 14th Dec 2014 at 21:55
cornish_pug
Changed out the strut today and spring, bearing was absolutely fine.
Clonk remains Angry
Could it have anything to do with the steering rack or even an engine mount, I'm running out of things to change lol.
Team Diesel
Posted 25th Jan 2015 at 16:36
Ball joints or engine / gearbox mount ? Or driveshaft - take your pick
Posted 25th Jan 2015 at 16:41
cornish_pug
Hmmmm Dunno
Team Diesel
Posted 25th Jan 2015 at 17:15
barrym
When my top engine mount failed the first symptom i noticed was a clonk when turning right? Also felt it through the pedals
Black Rallye occassional toy
Posted 25th Jan 2015 at 17:18
cornish_pug
It comes from gearbox side
Team Diesel
Posted 25th Jan 2015 at 17:23
pete-gti
drop link?
Posted 25th Jan 2015 at 18:06
cully
do you have the right length bolts on the top mounts
Posted 25th Jan 2015 at 18:11
balljoint
Posted 27th Jan 2015 at 10:47
cornish_pug
DROP LINKS AND BALL JOINTS ARE NEW ALSO
Team Diesel
Posted 30th Jan 2015 at 12:42
cornish_pug
of course
Team Diesel
luke89
Track rod end?
Posted 30th Jan 2015 at 16:24
cornish_pug
luke89 wrote:
Track rod end?
I'm thinking inner tie rob maybe, because I do get wheel wobble at 70.
All other joints are sound Crazy
Team Diesel
Posted 2nd Feb 2015 at 20:29
cornish_pug
Is it possible for the near side drive shaft to temporarily pop out then back in again?
Team Diesel
Posted 16th Feb 2015 at 18:17
cornish_pug
quote:
quote="monty-69"]On diesels i have seen the spring fail in the offside driveshaft inner joint
Could this be the problem?
Team Diesel
Posted 16th Feb 2015 at 18:44
cornish_pug
One more thing to add......
I replaced the standard wishbone bushes for aluminium ones I did notice that the main bolting face was thicker than the standard one. Could this cause the arb bush clamp not to fully clamp the rubber bush as it should. Keep in mind that this noise has only happened since replacing theses wishbone bushes.
Team Diesel
Posted 11th Mar 2015 at 18:45
cornish_pug
Measured the thickness of my alloy bushes on my wishbones and the clamping arm is 1.5mm thicker than the standard steel ones. Therefore the arb bush body isn't fully clamping the rubber.
could this be causing the clonk when turning right?
cornish_pug has attached the following image:
Team Diesel
Posted 19th Apr 2015 at 10:30
rallyestyle
Have you jacked it up and got somebody to turn it for you while having a look? Might help pinpoint the problem as it could be any of the numerous things already mentioned Yes
Just Drive It
Posted 19th Apr 2015 at 11:53
cornish_pug
Nothing is showing any signs of movement when jacked up
Team Diesel
Posted 19th Apr 2015 at 12:08
My Diesel does this when I turn one way & I was told by my Mechanic that several 306s he's had in have done this on N/S & he said it was the steering ram ?
Don't know if this helps ?
Posted 19th Apr 2015 at 16:08
