Anyone point me in the right direction of what I might be looking for? Or is it most likely going to be a change for another wiper motor setup?
| Author | Subject: Wipers only have 1 speed. |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
So I have the problem of my wipers only going 1 speed... Put the stalk to the first setting, and they go across as normal, but the next two settings don't vary the speed at all.Anyone point me in the right direction of what I might be looking for? Or is it most likely going to be a change for another wiper motor setup? |
Relay??________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Have you changed the motorcycle recently? What phase is your loom?=If you have a phase 2/3 loom and use a phase one motor intermittent doesn't work and the next two settings are the same speed If you have a phase one loom and 2/3 motor the same happens as above |
RetroPug
I changed the motorcycle on my 306s...solved a lot of electrical problems.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
pugheaven
Bloody auto correct.... Wiper motor |
devere
pugheaven wrote: Have you changed the motorcycle recently? What phase is your loom?= If you have a phase 2/3 loom and use a phase one motor intermittent doesn't work and the next two settings are the same speed If you have a phase one loom and 2/3 motor the same happens as above This could be it.... I have the cut down wiper motor that fits around the roll cage. Which I believe was used in the car as a phase 1 job. The loom I'm using came out of a phase 2/3.. So would be phase 2/3... On this basis, you think by using the motor out of the phase 2/3 car would solve the problem then... Bit of a strange issue to occur just through different phases! |
There's no change in part number, so its more likely to be a stalk or relay fault.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pugheaven
Yep using a phase 2/3 motor should solve it but you will.still.need to have the auto wipe sensor and loom if not you will have the same problem.Just put the sensor under the dash if you dont want it on the screen |
pugheaven
welshpug! wrote: There's no change in part number, so its more likely to be a stalk or relay fault. That's strange as its the same fault I had when I had phase 3 looms with phase 1 motor, changed the motor to the one I got out the phase 3 and problem solved Does the motor not have anything to do with intermittent on the phase 1s and rain sensitive on 2/3s |
I have a similar issue using a zx wiper in my phase 3 loomed car________________________________________ Nothing to see here |
devere
Im not sure whether my car ever had the rain sensor on it anyway!? I never had the auto wiper option on the car??Its a rallye loom if that makes any difference? |
I need to work my wipers out. The cage is in the way too on mine________________________________________ Nothing to see here |
