Author Subject: C5 steel wheel bolts
Mossy1985
As above, I've bought some steelies but I was told I need a certain type of bolt to fit them? Tapered with a washer I was informed, so looking for a full set thanks
Dave
Posted 11th Dec 2014 at 17:58
walker_texasranger
Dave, you can get them new from Citroen but they ain't cheap...
Hilux InvincibleX daily
306 No.13 Doh
Posted 12th Dec 2014 at 13:58
Mossy1985
Yea I was hoping to avoid the steelers John
Posted 12th Dec 2014 at 14:02
daver6
the bolts have a captive 60* taper washer with them, try Grayston engineering... they might have something suitable
Wishbone Polybushes available
Posted 15th Dec 2014 at 18:22
540572 superseeded by 1608734480 are the part numbers, dealers are about the same price as anyone else selling them bar a scrapyard, theyre about £2 each.
FEBI do them too, so many motorfactors can supply them.
they weren't limited to the C5 steelies, they were used on loads of cars.
Posted 15th Dec 2014 at 18:38
Mossy1985
Wow thanks WP, part numbers included (as if I expected anything less lol) much appreciated
Dave
Posted 16th Dec 2014 at 16:13
Mossy1985
Stealers are cheaper than febi!! Comes in a shade under 38 quid all in
Posted 16th Dec 2014 at 17:01
Mossy1985
Bought the bolts from pug and the bolts have the 60 degree taper but the taper is built into the bolt head ie no loose washer? Is this how the superceeded bolt is WP?
Posted 22nd Jan 2015 at 07:57
no idea I'm afraid, I've never needed to order any.
I do wonder if theres stock of the old part number anywhere still.
Posted 22nd Jan 2015 at 11:00
Mossy1985
The picture on service box doesn't show a washer but how accurate that is i couldn't say? Will fit them and do some miles and re torque them to see if i have had any movement
Posted 22nd Jan 2015 at 12:15
MisterGTR
Could maybe try this guy. http://www.mtec-racing.com/
He might not know about this instance. But when i was looking for the short (22-24mm) 19mm hex bolts that i was told didn't exist elsewhere he got them to me and for £1.89 a bolt delivered.
Or if you can get the specs there are tons on ebay (where i found mtec).
Posted 22nd Jan 2015 at 14:31
