RJ
| Author | Subject: Parameter measurement |
speedo306
Regular Location: Trinidad & Tobago Registered: 05 Apr 2008 Posts: 478 Status: Offline |
What are the correct parameter readings for the sensors on the 6 engine ie O2, stepper motor, throttle position, cool't temperature, battery volts, air temperature, manifold pressure. ________________________________________ RJ |
Mossy1985
Senior User Location: Darlington Registered: 04 Nov 2014 Posts: 545 Status: Offline |
These readings are going to change depending on what the engine is doing, ie pulling up a hill, sat on tick over, cold engine, warm engine etc, I'm not sure what you are looking for here?Dave |
woody.
Senior User Location: London Registered: 18 May 2009 Posts: 806 Status: Offline |
If you're looking for max and min values they are located here:http://www.306gti6.com/forum/showthread.php?id=80340 |
stan_306gti6
Moved to Engines. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
