Author Subject: Fuel pump relay
vandal.pr!
Are all fuel pump relays the same inside?
I got new one, it's not OE and it have lining pin on different position compared to my old one.
If i cut out that pin it would fit but will it work as intended?
Peugeot 306 s16 '97
Posted 20th Nov 2014 at 19:20
early cars have a different plug but the pins are arranged in the same way, you would be better to get the correct relay than try to modify it.
typically identified by having a brown casing and a brown plug with a small metal clip on RFY cars, RFS engined cars (6 speed) usually have a black relay and plug with a red sliding clip.
Posted 20th Nov 2014 at 19:31
vandal.pr!
Originally mine is black with red sliding thing, replacement one is brown for sliding clip (LCC 4104 i belive), and from '94 chassis i have brown with metal clip... that's cute...
So i should be searchig for gti6 one?
Peugeot 306 s16 '97
Posted 20th Nov 2014 at 20:22
if it doesn't fit, then yes Smile
Posted 20th Nov 2014 at 20:28
