Author Subject: Dropped bolt into the hole in the top of the gearbox!
luke89
Hi folks,
Whilst refitting the ICV I have dropped a bolt into the gearbox, I have no idea why theres a hole in the box but its a right pain in the arse.
The bolt is currently sat on top of the flywheel and I'm going to get a magnetic pickup tool tomorrow, however if I knock it down into the box will it be a box out job?
Cheers!
Posted 16th Nov 2014 at 00:08
clen666
I managed to get a socket in there, thought all was fine until it wedged itself between the flywheel and box.
Don't think the box needed to come out completely
Team 'unintentional rat look'
Posted 16th Nov 2014 at 00:23
luke89
How did you sort it without removing the box?
Posted 16th Nov 2014 at 00:39
clen666
I think it prises apart enough to get it out, I'm not 100% sure though, was a long time ago
Posted 16th Nov 2014 at 00:45
luke89
I think if I'm going to have to undo all the bellhousing bolts etc I may well just change the clutch whilst I'm at it.
Posted 16th Nov 2014 at 01:05
RallyeP6
At worst case, i would have thought if you put something under the engine to support it, then loosen the gearbox mount, few bolts that attach the gearbox to the engine/starter. You should be able to prise the gearbox aside enough to get access.
Posted 16th Nov 2014 at 10:51
pete-gti
Should come apart Anough to get it out , undo the bolts a bit on the box
Posted 16th Nov 2014 at 11:41
luke89
Sorted cheers folks! I got some super strength Gaffer tape and put it on the end of a long screw driver.
Posted 16th Nov 2014 at 16:06
