displaying posts 1 to 1 of 1
Author Subject: Cam/crank sensor
craig903
Hi, i'm currently at the stage off wiring up Dta S80 but not sure on the cam crank sensors and cannot find much info on them at all.
I've read that the crank sensor is a vr sensor although its a 3 pin plug just use pins 1 and 2 which are the signal and ground and then ground the shield at the ecu end. Is this correct?
As far as the cam sensor goes I can't find no info on it. From wiring digrams etc it looks to me as if it is a hall sensor. Does anyone know what pins the 12v, ground and signal wires go to?
Thanks
208 GTI Owner
Posted 8th Nov 2014 at 12:32
