| Author | Subject: gearbox diff bearings |
pete-gti
Seasoned Pro Location: Kent Registered: 15 Feb 2009 Posts: 1,297 Status: Offline |
Do these need a good firm tap to fit onto the diff? Or should they fit ok nice and easy , think I might have ordered wrong ones , ones I have are JL69349A/310/Q SKF Metric Taper Bearing 38/63/17 , but been told SKF JL69345F310Q Metric Single Row Taper Roller Bearing 38x63x17mm are the correct ones , ain't they both the same size? |
o.e were Timken or SNR branded, varied throughout production.Doesn't matter what the brand is as long as they're the correct size, you need a press to fit them properly, though if tolerances aren't too tight you may get them on with a suitable drift. certainly should not go on by hand. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete-gti
Will give these a tap with a drift see if they go on ok :-) what's the with same size but different part numbers by skf? |
different manufacturer?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
edit, nope, timken also list one under that number.,________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
pete-gti
Give these bearings a good tap tomorrow should go on , don't see how different part number will make any different if bearing is same size :-) |
Rich E
quote: [quote="pete-gti"what's the with same size but different part numbers by skf? Looking at the data on SKF's website regarding the two there are some small differences in roller dimensions ________________________________________ Rich |
pete-gti
Even when they say both are 38x63x17. There's about £5 different , |
