Author Subject: Flat spot when cold
barrym
After your help guys.
Since the weather turned a tad colder the Rallye has developed a flat spot/lack of power between 3 and 3.5K rpm on a steady throttle. This only happens when cold for the first couple of miles and if more throttle is given at this point it will go ok.
Also seems to be running very rich when first started, lots of petrol smell from the exhaust when maneuvering before setting off.
These symptoms have become apparent simultaneously. I'm guessing Lambda sensor but what do you think?
Oh yeah, car is up to date service wise.
Barry
Black Rallye occassional toy
Posted 29th Oct 2014 at 17:17
pete-gti
Get it pluged in see if its picking up any errors
Posted 29th Oct 2014 at 18:06
pug_306
Possible ecu temp sensor. Or have had fuel pump relays give simular syptoms
1992 205 GTi6
205 Turbo 340bhp
Posted 29th Oct 2014 at 18:52
Cjwatson27
Had I similar problem with my old 8v xsi which turned out to be the lambda sensor
Posted 29th Oct 2014 at 19:18
