Author Subject: Lightweight Flywheel is a bit tight
Eddleston
So I bought this
All was good in my head
Put everything in place and it just seemed a little tight on the locating pin.
Wasn't able to do what the piece of paper said - put it on to make sure it sits flush.
Looked at the flywheel that came off and it had circles round the bolt holes so it looked like it was slowly pulled on with the bolts being done nice and evenly. So I did.
Look at the locating pin now No
I think this dent will be OK though.
What do I do now?
a) cry
b] replace locating pin? and carry on
c) chip off the mashed piece of pin and carry on
d) try and make locating pin hole in flywheel bigger (I suspect not a good idea)
e) Start my life again
f) Burn everything
Posted 21st Oct 2014 at 14:37
walker_texasranger
F) Yes
Hilux InvincibleX daily
306 No.13 Doh
Posted 21st Oct 2014 at 14:40
Eddleston
Posted 21st Oct 2014 at 14:41
walker_texasranger
Eddleston wrote:
Disclaimer: I know f**k all about anything so could be completely wrong about F) and you may only need to resort to E) Thumbs up
Seriously, I can't tell you how bad that is. However, in my experience things that don't look like they did before normally need attention...
What I can tell you is that Rich's flywheels are a great mod and you will love it when it's all working as it should!
HTH Smile
306 No.13 Doh
Posted 21st Oct 2014 at 14:51
D, normal practice if its too tight.
Eddleston
Thanks for giving me some hope lads, it's now sat on quite comfortably. Never been so delicate with a grinder in my life, no chisel could remove the old mashed bit. Might try and stay alive for a day longer.
Question: Can I keep the old flywheel bolts? Or are they a compulsory change?
Posted 21st Oct 2014 at 16:20
I've always replaced my flywheel bolts with new when changing flywheel.
Posted 21st Oct 2014 at 16:33
Eddleston
I suspected that would be the case, turns out Mr Haynes recommends that too. The bloke at Peugeot said not to worry about my surname any more Roll eyes
Still, that means tomorrow is clear for searching for a torque wrench.
Posted 21st Oct 2014 at 16:59
