Cheers in advance.
| Author | Subject: Floaty feeling on 6 when driving.. |
willy1971
Newbie Location: Telford Registered: 06 May 2013 Posts: 12 Status: Offline |
Morning fella's...I still have a floating feeling on my 6 after replacing the following....bottom ball joints, tie rod ends, coil springs and P-bushes on the wishbones. Had the tracking done and tyre pressure is correct so after doing all of this I still have the same problem....getting fed up now as I have double checked everything over and over again. The only difference is the tie rod ends which are metal instead of the original plastic ones...will that make a difference in any way?Cheers in advance. |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
dampers that will be or mismatched spring rate to dampers.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
aaron6
How are you rear beam mounts? They can make for floaty handling. What air pressure do you run in the tires and are you still on 15's? ________________________________________ See the sheer power and might of the lesser known burrowing owl. |
stan_306gti6
Moved to Suspension. ![]() ________________________________________ "Supercharged - 454.1bhp/317.5lb/ft"Peugeot 306 GTi-6 2000 (X), Moonstone |
