Author Subject: air filter to inlet manifold pipe.
luke89
Hi folks,
Stupidly when trying to remove the airbox for cleaning I've managed to snap off the little tube that connects the small hose to the icv area.
I need a new pipe with the hose take off intact so I can get the car back on the road if any of you kind folk have one going!
Cheers.
Posted 11th Oct 2014 at 22:53
Push the plastic bit through the hose from inside out then reconnect the Icv hose
Posted 12th Oct 2014 at 00:09
luke89
Wont that cause an obstruction in the air pipe?
Posted 12th Oct 2014 at 01:27
Na
Posted 12th Oct 2014 at 09:29
luke89
Ok I tried to plastic weld this back on and completely buggered it by rushing and not waiting to do a proper job so I now desperately need a replacement as the car is now off the road.
Cheers folks!
Posted 26th Oct 2014 at 00:29
Puggitt
This. Any 'obstruction' caused by the lip on the inner air path would be the same as or less than the deformation of a plastic weld.
Posted 26th Oct 2014 at 05:25
Puggitt
luke89
That won't work now, In the process of melting the plastic the hole is now bigger than even the lip on the plastic take off piece so it just falls out so a new one is needed.
Posted 26th Oct 2014 at 11:26
