Author Subject: Door lock stuck?
luke89
Hi folks,
The drivers side door only opens when you turn the key and hold it turned, if you turn the key then centre it the door remains locked. Now I have removed the little plastic grommet from around the interior lock pull and without that fitted the door unlocks as it should.
This obviously points to something being misaligned in the door but does anyone have any ideas what it could be?
Cheers!
Posted 29th Sep 2014 at 22:48
Cjwatson27
My old xsi done this it was the door loom in the end
Posted 30th Sep 2014 at 06:26
Doorcard not on properly by the sound of it
Posted 30th Sep 2014 at 08:23
GTi6-PJL
Seconded on the door card card not fitted properly, or the rod that pops the locked / unlocked bit up and down is getting caught on the door itself. My 6 had the same problem after putting the card back on properly - the rod was catching on the door, so I bent it back into shape and all was good.
2000 W Phase 3 Moonstone.
Posted 30th Sep 2014 at 12:07
luke89
Cheers folks Ill have a look at the weekend when I'm off work, also need to recode the key fob amongst other odds and ends!
Posted 30th Sep 2014 at 22:24
