Author Subject: engine problem
speedo306
Hi all i am getting a problem whenever I try to accelerate I am getting some hesitation on take off and then the car begins to drive smoothly. I changed my aftermarket fuel pressure regulator and put back on the oem one, new k&n filter, new plugs, new fuel pump. What can be the possible cause of this hesitation. I am pushing a citroen vts engine in my ph 3 306. The only thing that came with the engine that I do not recognise is a blue filter like object attached to the vacuum line that heads back to the vacuum pump.
See pics below.
Can anyone assist?
speedo306 has attached the following image:
RJ
Posted 27th Sep 2014 at 23:50
take that thing off it's prob the problem
Posted 27th Sep 2014 at 23:49
speedo306
I looke it up here
RJ
Posted 27th Sep 2014 at 23:54
As I said bin it waste of time and does nothing !
Hesitation is usually a fuelling problem ? Check you have all the sensors plugged in ? Make sure air temp sensor is plugged in on the back of the throttle body ?
Posted 28th Sep 2014 at 00:41
