Author Subject: peugeot 205 rear dampers to peugeot 306
3gan
seen a set of these B46-1038 Peugeot 205 group n rear dampers
will these fit a 306?
with lowered rear beam
if they do how come they don't list them for the 306?
many thanks
Posted 24th Sep 2014 at 22:59
they should fit yes, but to what extent they'll last is another matter
http://www.306gti6.com/forum/showthread.php?id=157398
http://www.306gti6.com/forum/showthread.php?id=147938
Posted 24th Sep 2014 at 23:06
3gan
Posted 24th Sep 2014 at 23:14
allanallen
All the answers are in the threads rikky linked. Yes they fit and they'll be ok with standard bars. They're not listed for a 306 because they're 205 dampers.
Facebook
Posted 25th Sep 2014 at 06:49
3gan
many thanks for that buddy
Posted 25th Sep 2014 at 08:53
Very different damping rates on the 306 competition stuff as the bars used were much larger but the car not tgat much more on the rear axle
Posted 25th Sep 2014 at 09:28
3gan
by the looks of things these are standard replacements on a 205
the only thing that sounds good is that they were used in the group n cars
so I think I'll price up some b4 306 rears
cars stripped etc so no weight there at all
Posted 25th Sep 2014 at 09:31
allanallen
No they're not, they're different from standard, much firmer with more rebound. B4s are the oe replacement.
In my opinion the ones to go for are either 306 b6s which are slightly uprated but a better bet is the 205 grpA/2313. These work nicely with 20/21mm bars and are a better damper all round. The 306 Tarmac dampers are a bit ott I'd say, I've got a set on the rear of my 21mm barred 205 at the minute, I like them but they'd be better suited to larger bars IMO.
Facebook
Posted 25th Sep 2014 at 09:41
The fit fine and I have them.
I'm quite a fan but would also like to try b6's as a comparison.
Posted 25th Sep 2014 at 10:23
3gan
I'm either going B6 then or the 205 group n by the sounds of it
I have standard gti6 beam what would go for?
many thanks for the input people
failing that gaz golds as I would like to adjust them
Posted 25th Sep 2014 at 19:35
allanallen
Billies are better, I'd go for the grpN if you can't stretch to the grpAs
Facebook
Posted 25th Sep 2014 at 19:57
3gan
cheers buddy
if I go for these £150 bargains do you think they are suitable
for a lowered rear beam?
I always try and stick to a budget and was hoping to spend no more than £150
but if I have to maybe £200
it's frustrating knowing so little about my new project
all your help is much appreciated indeed
Posted 25th Sep 2014 at 22:45
3gan
just got this from eBay
Bilstein Peugeot 205 Group N Challenge Rear Dampers
Pair of Bilstein Motorsport Spec Rear dampers for Peugeot 205
These are the Group N Motorsport spec dampers
Bilstein B4 range is original equipment replacement shock absorbers. These shocks are gas pressurized with a twin tube design.
As used on the 205 Rally cars, also Ideal for 'Fast Road' and 'Track-day' use.
Genuine Bilstein, made in Germany
Sold as a Pair (x2 Dampers)
Posted 26th Sep 2014 at 01:04
3gan
now this is interesting and so confused me I don't know what to do
http://forum.205gtidrivers.com/index.php?showtopic=135316
Posted 26th Sep 2014 at 02:39
allanallen
As you can see that's my thread! I was after motorsport dampers for a rally car so I didn't want the grpNs which are basically a differently valved b6 (I think?). This is why I recommended you the grpAs rather than the cheaper ones you're looking at!!
GrpN/1038 uprated damper used on the challenge cars with standard bars
GrpA/2313 bigger bodies, more damping/rebound for bigger bars
Facebook
Posted 26th Sep 2014 at 07:10
3gan
cool many thanks
I run a recon rear beam but its all standard
personally I would go for the grpA2313 but probably have a better ride in and off track using the 1038
I'll get looking again this weekend as cars booked in for work Friday
gotta get my finger out!
cheers buddy
Posted 26th Sep 2014 at 09:17
You wont be disappointed to be honest
Posted 26th Sep 2014 at 09:57
3gan
Group A 2313 has everyone's vote yes :-)
Posted 26th Sep 2014 at 11:20
