| Author | Subject: Leaving CTS unplugged? |
RetroPug
My cts has snapped in half but is still sealing. If I leave it unplugged will the engine just default to running rich? Will there be any problems other than worse economy?________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
eventually you'll have a knackered cat and pistons rings from running too rich, after that it'll be bore wash and a knocking bottom end from contaminated oil.that's just the worst case scenario of course. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Ok.I've a whole spare housing on another car but I can't get one of the bottom hoses off for the life of me, or I could drill the CTS out I suppose. I need the car to go to work in the morning! The sensor has a plastic core inside the metal, I'm wondering if the metal is just heat-conductive casing? ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
loosen the 13mm bolts holding the metal pipe onto the block and you'll get the pipes off the back of the thermostat housing.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RetroPug
Ok thanks I'll have a look at that.I've superglued the sensor together, and I'm hoping that I'll be able to wind it out if it holds together. Edit: Undoing that bolt worked really well, thanks. ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
RetroPug
If this listing is to be believed, the CTS is common between the gti6 engine and the S16 etc. Is this the case?I don't imagine a peugeot one being this cheap and they almost certainly aren't made by peugeot anyway. The one that snapped in half was from a dealership! ________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Cjwatson27
Looks the same has the one i ordered mate ________________________________________ Old pugs don't die they just get faster |
RetroPug
Yeah it definitely looks the same, but it is whether or not it gives out the same voltages for the same temperatures etc. It is very likely to be the same. I suppose when I stop being lazy I'll check part numbers on service box or something.________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
Cjwatson27
Yeah I would avoid it then if its fitted to mine that engine is in a really bad place at the moment lol________________________________________ Old pugs don't die they just get faster |
RetroPug
Hesitation has actually all gone so not necessary any more!________________________________________ 61k miles Ph.1 Diablo '6 Project Thread |
