Author Subject: 4 port master cylinder upgrade
craig903
Hi, I'm currently rebuilding my '6 and have removed the abs. I have a 2 port abs mc i now need a 4 port and i would prefer to buy one with a bigger bore to reduce the pedal travel. I do plan on getting 300-350mm brake setup soon. I've found a little guide on here linking to a bigger 2 port but i'm not sure what will fit in the way off 4 port mc's.
any idea's?
208 GTI Owner
Posted 13th Sep 2014 at 18:39
devere
For what reason do you need it to be 4 port? Standard is only 2...?
Posted 13th Sep 2014 at 18:54
pug_306
As hes removing his ABS, you can run a 2 port and split it or i ran a 406 non ABS master cylinder but still the same size as a gti6 im unsure if theres any bigger 4 port ones available.
1992 205 GTi6
205 Turbo 340bhp
Posted 13th Sep 2014 at 19:10
just add some non abs tee pieces as per all RHD non abs 306's, which all ran 2 port.
Posted 13th Sep 2014 at 20:20
